OTA Tire Size Update
Spaceball1
Danny
Colorado Springs, CO
22 R1T, 23 Kia EV6, 15 Mustang GT Vert
Mechanical Engineer
Recently switched to 20s from 22s. Thinking the speedo has gone from showing 1 mph faster than actual to about 1-2 mph less than actual. What are the consequences of not getting the cameras recalibrated? Don't really care if the screen shows the wrong wheels.
I mad the same switch and mine is actually dead on accurate with the 20s. I didn’t really check it with the stock 22s to compare unfortunately. But I’m also wondering what the advantage is for recalibration. I haven’t seen any negative side affects, other than occasional tire rubbing, which I’m not certain it is related to any calibration anyway.
WSea
Patrick
West seattle
R1T, Outback
Architect
Did you check with a gps speedo app? What scenarios do you get rubbing. No tire rubbing here.
Spaceball1
Danny
Mechanical Engineer
Yes I checked with two different GPS apps. Thought I didn’t think ahead to check it on the stock 22s before I switched them out.
I’ve heard rubbing on a dip in my road are an intersection, where turning into my street. So I’m in a situation where I’m turning and hitting a dip at the same time at around 5-10 mph.
The only other time I’ve heard rubbing is going in or out of my driveway, again with wheel turned sharply. I did used to have kneel mode enabled which I’ve noticed it doesn’t come out of it right away, so I believe but not certain the truck was in kneel mode still when this rubbing occurred. I’ve since turned off kneel mode and haven’t heard it rub on my driveway, But that’s unfortunate to have to do since my wife and son really like the kneel mode for getting in and
Went through some wicked speed bumps (super slowly in a oarkyesterday and no rubbing, but my wheels are straight in that scenario.
