Recirculating mode
irvineboy
Orange County
I notice the recirculation mode does NOT save. I press the button and it will show the black color with the arrow, allowing air to recirculated. But when I park the car and lock it, when I come back to it, recirculation mode will be off. Button is grey with the arrow coming into the car icon. Does this happen to others? Is there a way to keep it saved?
mkg3
R1S, Model 3, Outback, Artura
You probably have the temperature set to "Auto". It will cycle between recirculating and outside air depending on the temperature difference between outside and inside.
I do not use auto mode and is set to AC year around at 65 and adjusted up when necessary in the winter. Its always set to recirculating and stays on that.
Turn it on and it will stay on. That said, it will also randomly cycle on and off based on humidity in the cabin and A/C status.
irvineboy
Orange County
So it’s normal for recirculation to turn on and off randomly? It’s doesn’t just stay on once you turn it on, all the time?
mkg3
I don't think its normal to turn on and off if you are not on auto.
what temperature do you have it set to and are both driver and passenger sync'd?
Not have experienced this issue. My R1S is a gen 1 quad June 23 build. Perhaps it has something to do with gen 2, since HVAC was changed to accommodate a heat pump for the cold.
Yes. I put in a ticket a while back because it would turn itself off and that was the response. Now I leave it on and will occasionally see it turn itself off, but it always comes back on.
I will say that I tend to stay in Auto, but I used to only run in manual and it did it then as well. I'm Gen 1 as well.
jerseyff
Darren
McDonald, TN
R1T; Model 3 Highland
Seat coolers also now always revert to seat heating. I've rebooted infotainment, restarted vehicle, deep sleeps....nothing makes the seat cooler comg back on first press. This started with 2025.10.01, not fixed in 2025.14.01...I did submit something to service for bug purposes.
It's automatic based on outside temp. They don't publish the thresholds though.
HaveBlue
It was 111F yesterday and the seats default to heat on mine. They always have done that for me no matter how I leave them. There are so many settings that do that, I gave up.
