Road trip nav help -
azbill
Bill
EA doesn't have the ability to add inbound cars to their availability algorithm like Tesla does
Now that Tesla supports other OEMs, that algorithm is not much better than EA. I tend to look at the status a few miles from the charger exit, and if there is an alternate, I go to that if it is indicating full. If there is no alternate, then the status is useless, just have to wait in line.
BigSkies
R1T, Model Y
I haven't tried this since the Google Maps update, but I've had good luck with the "add charger to route" function. It seems to recalculate pretty well.
A couple other things that help me:
1. While I plan routes in full day segments, I set my nav for shorter segments. For example, I'll commonly set my nav to wherever I plan to have lunch instead of my final destination. I don't know why this seems to help, but it does.
2. I build a quick mental-model of my charging options before departure. Just looking through chargers on Plugshare, ABRP, or Rivian before I leave will give me a good idea of where I might charge. I'll commonly do something different than what the nav suggests because someone has to pee, I need to stretch my legs, or whatever. It also helps to know where your good backup options are beforehand.
You don't have to memorize it. Just have a rough idea of options. Use the nav as a general guide on charging and not gospel.
3. I try to mostly charge in more rural areas when on the road. Densely populated urban areas have chargers that fill up. This is rarely true in the middle of nowhere.
Reactions: VSG
