Scheduled preconditioning doesn’t pull from shore power first
NineElectrics
I’ve been using the new scheduled preconditioning feature and told it to pull from the wall. It looks like when the car is heating, power isn’t taken from the wall continuously. Sometimes the battery drops by about 2%. Looking at my ChargePoint, I see spikey charging.
I conclude that unlike most EVs, the Rivian lacks the capability to preferentially draw from shore power when heating. All heating power comes from the battery, and then the battery is periodically refreshed.
So, you’re not saving charge cycles by leaving the car plugged in, and depending on when you leave you may have 2% less charge than you want.
This is pretty dumb. What other basic hardware features did Rivian designers overlook, I wonder? Besides the heat pump?
Electrified Outdoors
Mount Airy, Maryland
EVoutdoors.org
Real Estate
could this be by design? Wouldn't cycling the battery heat it up more? I have to look closer at this...didn't notice any difference in battery on the recent road trip.
NineElectrics
NineElectrics
That could well be, but I would prefer not doing that as I want my battery to be as close to the limit that I set as possible before departure.
atebit
R1T, Porsche Boxster
Not precondition-related, but it’s always annoyed me that the truck does not draw from shore power when connected & the HVAC’s operating (unless it was already charging). IIRC my Tesla’s would always draw from shore power in that situation. Seems like a table-stakes design feature to me. But then again, so does cruise control “resume”. :rolleyes:
mtberman
Terry
2023 R1T DM large,2019 Chev Bolt, 2021 Audi e-tron
Mine does. When at or above the threshold I’ve set, my charger kicks on if I activate the heater.
zfischer
New Mexico
Sprinter, 1250GSA, R1S
I doubt it but could the evse matter? Like, works with Rivian boxes but not necessarily others?
NineElectrics
NineElectrics
My ChargePoint does eventually show a power draw, but it’s only after the battery drops 2%.
rivianunder7
West coast
2023 Rivian R12
Very interesting
DTown3011
I have tried the schedule preconditioning a handful of times and currently have my vehicle set to only charge between the hours of 9 PM and 6 AM due to time of use charging rates. The only time my battery has been preconditioned is if I leave before 6 AM, which tells me, it’s not pulling from Shore power or the charger if it’s outside of the scheduled hours in the setting. I think the time schedule over rules the precondition schedule. I’ll try it next time without drawing from the charger and see if that works outside of the scheduled hours.
GA_Rivian
Ovando, MT
I'm in a similar situation, but don't drive that often so it's a bit harder to check. I also sometimes have the cabin temp power turned off because I don't care about conditioning the cabin before leaving. But it appears that even though the cabin temp schedule is activated, with the power off and outside the charge window the battery isn't conditioned.
WSea
Patrick
West seattle
R1T, Outback
Architect
Used schedule yesterday morning and it worked exactly as it is supposed to if you toggle energy usage for it to pull from charger (EVSE) to maintain range
tate16t
Robert
2023 El Cap Granite R1S
Car Enthusiast
I scheduled a pre-condition this morning and selected “pull from charger to maintain range”. It did not pull from the charger. My battery % dropped. Just before the session started I realized it did not require defrost so I edited the session to remove this and saved it. The pre-condition session appeared to start immediately after saving and did not pull from the charger. Maybe my action caused it not to pull from the charger?
captainjp
New Jersey
Gen 2 R1T
The vehicle uses its high voltage battery to power climate. When state of charge drops below your set point, the vehicle calls for charge to return to that level. I’m pretty sure this overrides any charging schedule you may have as well
tate16t
Robert
Car Enthusiast
If I set my limit lower then the state of charge it will pull from the charger when I schedule a precondition?
captainjp
New Jersey
Gen 2 R1T
Negative. It never will. All systems are powered by battery (high voltage or 12v) Charger only supplies power to charge high voltage battery. The language is misleading, however you’re achieving the same goal, which is to maintain your state of charge while conditioning your vehicle.
