I'm no help in fixing the issue but, if you're near a Service Center, my suggestion is you drive there first thing tomorrow morning and ask that they escalate the fix, particularly invoking the word "safety." The second time my latches failed, I was able to get them replaced the same day using that tactic (rather than waiting weeks for the scheduled appointment). Assuming they have latches on hand, it's a quick fix. YMMV, of course.I can hear/feel that the right side latch isn't being activated when I try to drop the tail. I have a service appointment but it is a couple of weeks out.
Is there an easy way to reach or manually pull the latch in the meantime?
That's a very good point. I'd much rather have it stuck shut than fall open or stay open on the road I guess(By the way, if get the gate to open, you may not be able to get it to close again, so think about which scenario--stuck open or stuck closed--is worse for your situation.)
Either way, you can pitch it as a safety issue: stuck open is bad for driving, while stuck closed is bad for replacing a flat when you're out of cell range in West Virginia.That's a very good point. I'd much rather have it stuck shut than fall open or stay open on the road I guess![]()
I had my tailgate latch replaced as well, it wouldnt hold and the caralways thought it was open so it would mess up the parking sensors. One workaround to make it stay closed is to close it and hold it for a good 10 ish seconds with both hands on the far left and far right side and it SHOULD hold.I'm no help in fixing the issue but, if you're near a Service Center, my suggestion is you drive there first thing tomorrow morning and ask that they escalate the fix, particularly invoking the word "safety." The second time my latches failed, I was able to get them replaced the same day using that tactic (rather than waiting weeks for the scheduled appointment). Assuming they have latches on hand, it's a quick fix. YMMV, of course.
(By the way, if you get the gate to open, you may not be able to get it to close again, so think about which scenario--stuck open or stuck closed--is worse for your situation.)
Both of my latches were replaced at start of this year, after falsely and incessantly reporting possibly "person or animal" being in the bed when it was just air. Two weekends ago, during a heatwave in SoCal, the tailgate failed to drop. At first I thought the latches did not release. But soon realized they released, the taillgate just didn't drop on its own. So... just FYI, this may not be finished business. I'm almost tempted to install one of those aftermarket spring loaded door poppers that hot rodders and modders install once they've shaved their door handles. Or, opposing stick-on magnets.Mobile service came by and fixed it on Monday. Took 30 minutes and I'm back in business!
