The Next BIG Thing in Rivian Tools
electruck4x4
electruck4x4
Electruck4x4.com
Ah, ok. The above setup ought to work then. You should be able to get the wheels off the ground without the boards as long as you are on a hard surface. Boards will help though should you be on dirt.
Tim-in-CA
So Cal
Gen 1 R1S, Lucid Air, T-Bird
I received my jack pucks today and also purchased the below bottle jack:
BIG RED T91003B Torin Hydraulic Welded Bottle Jack, 10 Ton (20,000 lb) Capacity
https://www.amazon.com/dp/B002E1AYHW
However, the top of the bottle jack (saddle) does not fit into the hole in the base of the puck, what jack has been tested to work with the puck? I’d assumed that Big Red would have worked seen as it’s a popular jack. Thanks.
