Turn off screen torch mode when reversing?
Surferdude
Hawaii
Tesla
Is there a way to turn off the super bright back up screen when reversing? I've never owned a vehicle that uses the same brightness level on the reverse camera screen at night as it does on a bright sunny day. Every other vehicle would dim the brightness down to accommodate the actual ambient lighting. I'm hoping it's a bug and not intended to be this bright.
MtnRiv
Lake Tahoe
2023 R1S
I haven’t had this issue. It stays at whatever brightness the screen is set. I wonder if it is an option somewhere. Hopefully it is a simple fix!
Regulatory requirement doesn't take into account ambient lighting conditions. Blame the FMVSS.
thehodge
Tuolumne County
R1T, Tesla MS Raven
I'd like an independent brightness control for each screen.
When I shut down the car with the screens at their lowest light settings, they stay at the lowest light settings when the car powers up. Just to pause here & say: I like the lowest light setting. It's what I like for driving in the dark. It's so perfect that I can't see it in the daylight & I'm privileged to have to swipe randomly in the screen area where I'm pretty sure I'll find it. Cataract surgery didn't help.
Independent brightness controls or a setting for a default "start up" brightness.
racekarl
MA
So all other automakers are not compliant?
If they aren't bright enough to follow the regulations, then yes. Initial image in the display has to meet the requirements for the illumination test. There is no nighttime illumination test. IMO this is a failing of the regulation, as your complaint is not unique.
The ambient illumination conditions in which testing is conducted requires that light be evenly distributed from above and at an intensity of between 7,000 lux and 10,000 lux, as measured at the center of the exterior surface of the vehicle’s roof
If you're not familiar with the lux measurement, this might help put the testing range into perspective. https://en.wikipedia.org/wiki/Daylight
And if you're curious, here's the test procedure. https://www.nhtsa.gov/sites/nhtsa.gov/files/documents/tp-111-v01-final_tag.pdf
