UHF doesn't switch lanes with signal on non highways?
2026 Ram RHO, 2024 i4 M50
I was trying to use UHF today on a six-lane road (three each way). I wanted to merge over a lane, so I used the signal, and it showed a solid red line in the direction I wanted to merge. Does the auto lane change not work on UHF? The lane I wanted to move into was clear, and the road was perfectly straight.
Engineering, Dog Petting
Seems not to. It'll let you do it though. I did have it work on a highway that D+ works on.
It did let me do it without cancelling the whole thing. I wonder why no lane change.
Only works in the sections that are mapped, i.e. the roads where HA/RAP worked before.
iowa_don
Don
R1S Gen 2
That is how 2025.38 was working for me on roads that were only mapped "sort of". I travel on a road that has been under construction for several years adding a lane. It was finally finished 6 months + ago. As far as my Rivian was concerned that third lane (the car thought it was the left most lane) did not exist. The other two lanes were just fine but I could not change lanes to the left. I got the "red line of death". The more interesting thing is that if I manually changed to the far left lane, I could use driver+. Crazy.
CO Riv
Doug
2023 R1T and 2025 R1S
Definitely does not work automatically. I drove 200 miles on 4 lane divided highway. Put blinker on, pull steering wheel to change lanes, continue holding steering wheel and blinker will automatically cancel and lane assist will reengage.
portdirect
Missouri
Blinkenlight Hearder
That's my experience also. I find that I can use the steering wheel th change lanes without causing UHF TO disengage.
And the autonomy view is *almost* useful in the zoomed out view it goes into whist doing so
rutiger
2 x '25 Tri S's, '25 750S
I've found while it doesn't support auto lane changes I can still put blinker on, change lane manually, and then UHF stays enabled after lane change. So, at least that's good that I don't have to reenable UHF.
