EV Sportline
evsportline.com
Upgrading Electric Vehicles
Just got a set on the R1S - https://evsportline.com/collections...l-wheels-for-use-with-rivian-r1t-r1s-set-of-4
  • Size: 20x8.5" Front, 20x8.5" Rear
  • Offset: +40 Front / Rear
  • Bolt Pattern (PCD): 5x5.5 (5x139.7mm)
  • Engineered by Team 1EV for use with factory Rivian lug nuts (not included)
  • Engineered by Team 1EV to use factory Rivian TPMS (not included)
  • Engineered by Team 1EV to use Rivian center caps (not included)
  • Bi-Directional, okay in any wheel position
  • Anti-Slip Knurled Bead
  • Center Bore: 64.1 mm
  • Construction: Fully Forged
  • Weight: 31.9 bs
  • Load Rating: 1,125 kg/2,480 lbs
  • Recommended Tire Size: 275/65/20
  • Colors: Satin (Matte) Black or Diamond Black
Rivian R1T R1S R600 Fully Forged Aftermarket Wheels by Team 1EV on Rivian R1S r1sr6001
Rivian R1T R1S R600 Fully Forged Aftermarket Wheels by Team 1EV on Rivian R1S r1sr6002
Rivian R1T R1S R600 Fully Forged Aftermarket Wheels by Team 1EV on Rivian R1S r1sr6003
Rivian R1T R1S R600 Fully Forged Aftermarket Wheels by Team 1EV on Rivian R1S r1sr6006
elektrode
Bran
NC
Honda Ridgeline to R1T
They look pretty sweet!
mabowden
Socal
Toby Flenderson
Very sharp. Well priced too. Probably the best option for aftermarket wheels to date.
zefram47
Rivian R1T, Alfa Romeo 4C
Still nearly twice the price they should be, but these look 10x better than the R500. Well done on the design! Maybe a bronze option will come later, or was the take rate not high enough on the R500 to justify it?
cohall
2022 R1T, 2023 R1S
They look great. Are there any benefits over the OEM 20's other than the look? Just curious if they're lighter, stronger, etc.
Thanks.
Sgt Beavis
Rick
Overpaid Computer Nerd
Those are VERY nice. I'm just not to the point that I want to replace my OEM wheels.
seanocono
Sean
LA
Tesla Model X Plaid, GMC Sierra Denali EV
Thanks.
Click the link. The benefits are listed in the description.
These are good looking options. I especially appreciate the ability to save a little bit on an order of 5, and the option to order single wheels, as well.
Mathme
Los Altos, CA
High Tech
This would be a nice option for a set of dedicated winter tires...
EmPickle
Jason
North East
Model 3, Honda Odyssey, Miata
Geek
camaroz1985
Carlisle, PA
R1T, ID.4
Looks like a 6 staple version of the factory 5 staples.
TollKeeper
Brighton, CO
Ast HR Director
Designer get lazy and borrow a wheel from GMC?
Rivian R1T R1S R600 Fully Forged Aftermarket Wheels by Team 1EV on Rivian R1S MG_1223_95d7f7ce-73de-42df-a4db-a39f64460247_3251x
obfuscurity
Jason
Westminster, MD
Rivian R1T, Tesla Model 3, Audi SQ5
@EV Sportline can you speak to your customers' experiences swapping these in for a different wheel and tire combination (size)? I'm considering these as a swap from my factory 22's but I've various rumors about whether Rivian will (or won't) support aftermarket wheels afa the software reconfiguration.
EV Sportline
EV Sportline
evsportline.com
You should be able to get the Rivian service team to update the size noted on the screen. However, the wheel configuration on the screen is meaningless as far as I can tell. The tire diameter is what technically matters for speedo, not the wheel diameter. I've swapped multiple size wheels over time, can't tell a difference. Maybe it makes an ever so slight difference in the range predictor, but I can't tell.
NineElectrics
Someone else weighed the 20" wheel-tire combo and it was 88lbs. Apparently the Scorpion weights 57lbs, so these wheels actually weight 1lb more than the stock. But they do look good.
This page has the Rivian Scorpion OEM tire at only 48 lbs: https://www.tirerack.com/tires/tire...R0SATPV2&vehicleSearch=false&fromCompare1=yes.
There are multiple load ratings for this family of tire, one of which is 57 lbs, but the above page lists this 48 lbs model as Rivian specific.
