120V outlets not working
^ that's certainly good to hear, because it seems the SC's have been dismissing owners out of hand with even higher than 2% per day stating "up to 5% loss/day is normal, no corrective action required".
Ralph
Ralph
Arkansas
R1T, Outback
Would be surprised if your AC will run off the outlets in the R1. Many of us with campers have tried it to no avail.
A/C units require much more power (amperage) to start up than they do to run. Many RV'ers using generators have had success in reducing the start-up power required by using a Soft Start device such as this. This allows them to use a much smaller generator than without.
The device linked purports to be able to start two A/C units with a 2200 watt generator.
Depending on your needs it might be worth a try.
Note: this is not a solution for a situation where continuous power requirements greatly exceed the inverter.
dode
Anthony
Ventura
Glad to hear others are having issues and I'm not alone. My 2023 R1T's outlets are out after trying to charge a battery pack in the bed.
I have a service apt soon but they want me to sign a work order for $1600! My jaw dropped. To change a fuse?!! Seems like this is a design flaw.
Any advice?
Hereforthesnacks
West Coast
Ford Bronco
Any advice?
How is this not under warranty? I’ve seen some posts asking folks to sign a WO, but they were never charged since it was warranty work….
Oldsmobile_Mike
Manassas Park, VA
FG/FE R1T recv'd 3/31/2023
I build stuff
Agreed. Believe this is standard procedure. You sign the work order, but then it gets dismissed or waived once they confirm the work is performed under warranty.
Cibby
Mill Valley, CA
2025 R1S
Having the same issue. Is it just one fuse to check or more than one? Is that something I could try replacing on my own if it’s blown? Curious what I can try while waiting the month plus to get a SC appt
