JeromePowell
Chapel Hill, North Carolina
2023 Audi E-Tron Chronos, 2007 Porsche Cayman S, 2010 Nissan Xterra Off Road
So today, I did notice once issue: Alexa went on vacation (no voice guidance in nav). I am not sure if it's related to my customary soft reset (after each OTA), because it didn't do this with past resets. Was about to shoot a note to Support when I decided to disconnect from Alexa and signing back in. That did the trick. Hope this helps someone out there.
IGR
I make things
After this update my battery stopped preconditioning when navigating to fast charger, battery temperature was around 50 at the time.
Soft reset did not help, any one else having this issue?
VSG
R1T LE/RB/OC/20
The vehicle will only precondition the battery when it needs to precondition - just routing to a DCFC isn't enough. What makes you think it needed preconditioning?
That's what I was just going to say. Plus, are there any visual indicators telling you that the vehicle is indeed preconditioning? I don't think there are? 50° is chilly to humans, but not so cold for battery chemistry and cells that they need warming up.
RivianRiverRat
Greg
Chattanooga TN
2022 Rivian R1T
Civil Engineer
manual say it's under charging stops (page 185 depending on version) - if battery temp needs to be hotter or colder for optimal charging it will do so and show "pre-conditioning battery" on main screen and driver screen - so I guess that you have to navigate to a charger to get the info
Kitsap, WA
There are options. I see three levels of regen in all-purpose. And "high" isn't necessarily the same as "high" in snow mode. Different companies approach software differently.
I'm perma-low regen, and I still get complaints. If I even try regular or high, I get the accosting "WHAT ARE YOU DOING" comments from the peanut gallery. I may try snow low, haven't used it for regular driving since they added it to AP.
iforbes
Ian
Connecticut
APRN
This is user error. You should feather acceleration/deceleration to effectively mimic a regular car. If you are getting comments, no offense, you are doing it wrong.
