2025.14 - Phantom Battery Loss
SPITmadFIRE
2024 R1S PDM Max Pack 20" AT
Unfortunately, 2025.14 seems to have been a big step back on the vampire drain. Even with my vehicle hooked up to an OBDII battery tender, I'm losing about 5mi of range (around 2kW) every 24 hours.
Is anyone else experiencing this?
Tim-in-CA
So Cal
Gen 1 R1S, Lucid Air, T-Bird
YES!!! OBD2 battery tender charging doesn't seem to be working. I rebooted and decided to take the OBD2 charger off and now my vehicle has stayed awake 8 of the last 12 hours and lost 1.1%/5mi of range. Same thing yesterday even with the OBD2 battery tender connected. Pretty frustrating!! I'm going to try rebooting again later and reconnecting the OBD2 charger.
Tim-in-CA
So Cal
Update ... I thought I was already updated to 2025.14, turns out I'm still at 2025.10. I just received the update notification for 25.14, I'll let you know if my VD has changed after I install and monitor for a day.
DayTripping
Timothy
DFW
The day I upgraded mine, it was horrendous. Since then it seems to be better than it was. I am using a battery tender as well.
Unfortunately, Electrafi stopped tracking for 2 days due to a token refresh issue so I don't have as much data as I'd like so far but it is looking pretty good at the moment.
bigsky
MUM
MUM
2025.14.01 installed yesterday around 7 PM @ 108 35% SOC. This morning, SOC is 107 35% or -1 0% loss. Typical daily loss can be as low as 0 to 4 miles. VD seems normal, unchanged with new update.
R1S quad with OBD tender hibernating since last November.
Tim-in-CA
So Cal
Here's my update. Prior to 2025.14.01 install, I started seeing excessive VD from this past Saturday even though I'm connected to a Battery Tender via OBD. After installation of .14 on Tuesday, I decided to to dig into my settings to see if anything changed. Lo and behold, GG Motion events at home was turned on and I saw trigger events from Sat, Sun and Monday every time I went into the garage. This was the source of my VD. On Saturday, I noticed that my GG drive wasn't being recognized, so I had unplugged and replugged it back in. Perhaps GG at Home was enabled at that time.
Now that .14 is installed, my R1S with OBD tender connected has been sleeping for 17 hours straight.
