12V Battery Replacement Megathread
DuoRivians
R1T, R1S
Ossevirum
Matthew
Pittsburgh
Rivian R1T, Ford Mach-E, Chevy Bolt, Chevy Volt
Attorney
Just got my warning today - wrinkle...... I live in Puerto Rico and we have no service center here. Sooooo.....
I saw some people mention a battery tender as a way to make sure you can limp along, did that work? Willing to jerry rig pretty much anything to keep this rolling along.
I have to order batteries either from Rivian or Ommu and install them myself, period. So, hopefully I can clear the codes or whatever.
Question - if you can't clear the code but have replaced the batteries - do they function normally? I can live with that error so long as the truck starts and drives fine.
Blackhatch
DC
Self
Anyone else on the battery issue train? Any other commercially available alternatives?
TheIglu
Clayton
North Central MA
2022 Rivian R1T
It worked for me for a few days, but that's it before I got my batteries swapped. Just left the tender leads hooked up and ran the tender wires into the frunk to be plugged in.
Funny enough, I was plugged into L1 charging at 8 amps overnight while the tender was on, and managed to get something surprising in charge (like 10%!) overnight. Normally I don't see that sort of charging on 120v even at 12amps. I guess the 12v batteries charging definitely do suck up a ton of power.
I'll add a pigtail and plug the tender in for any long parks once I have a place to charge at home again. Apartment living sucks....
sherold
Indiana
Audi S3, VW Atlas
Anyone else getting the notice post update?
Mine popped up around the 10th, a few weeks after the update. I have not replaced them yet and, all is well for now.
Blackhatch
DC
Self
Was seeing what DuoRivians went with, battery wise.
I am in your boat. Update and 1 week later..."Battery Issues". I am just leaving it plugged in at home. But will probably need to fix it prior to selling it.
freshpow
My battery warning popped up last month and I managed to go a little over 3 weeks without any issue, but made sure to keep the truck plugged in to my wall charger whenever possible. A little after 3 weeks, I got turtle mode and a number of other error codes. A hard reset got rid of all those error codes for the time being, but I figured that meant it was finally time for me to replace the 12v. I replaced with the Ohmmu Sodium and all good so far. I expect the Ohmmu battery to last a lot longer than the OEM. I only got about 2 years out of this last one from Rivian and don't care to pay $500+ every couple years for something that is easy to DIY and much cheaper.
A quick battery test on the OEM 12v I removed confirmed that it was indeed cooked.
Rivian R1T R1S 12V Battery Replacement Megathread IMG_1484
I tried a 12v repair with my NOCO Genius5 but that only made it worse.
If anyone is looking for a single Ohmmu 12v, I have an extra one for sale here (ordered 2 but only need 1).
