275/55R20 Tires - recalibrate speedometer?
Malkozaine
James
Chicagoland
No Rivian Yet
Drone Pilot
If I got 275/55R20 tires, can Rivian recalibrate the Speedo to them?
Early on there were a few reports that Rivian did this. But I don't recall any recent reports. FWIW, from what I have read, neither Ford nor Chevrolet will do a recalibration for non-standard tires either.
jjswan33
Joshua
Sandy, OR
FWIW if you are currently running a 33” tire (the 21s or 22s) I wouldn’t worry about recalibrating the speedo, it likely will not be very far off. Going from 34” (OEM 20”) size would be a pretty large difference though.
jjswan33
Joshua
Sandy, OR
Malkozaine
James
Chicagoland
No Rivian Yet
Drone Pilot
I know you weren't asking for this advice but a 113 load rating is quite a bit lower than OEM 116. Most big tire shops won't even install them for you. Although 2535lbs is more than 2466lbs (Rear GAWR 4932lbs/2), there isn't a lot of buffer there.
These are the ones I was more looking at, I just want to see if it was possible to go smaller and get the Speedo fixed for it.
https://www.tirerack.com/tires/hankook-dynapro-at2-xtreme
275/60R20 - 115T
Or these:
https://www.tirerack.com/tires/tire...ewall=Blackwall&partnum=76TR0CCLX20&tab=Sizes
Kitsap, WA
