mikehmb
SF Bay Area
Some info for those on the fence about going to all-seasons ...
I want to preface this by saying it's very much too early to draw long-term conclusions, but as expected, the Michelins are providing considerably better efficiency than the AT OE tires.
This is not a surprise at all. What -is- surprising is that I kinda like how they look, despite being a long-term AT tire person on all my other trucks.
I was seeing 2.23mi/kWh lifetime on the OE tires. Seeing over 2.9 now, over around 30 miles, though that will reduce considerably over time for sure.
15-min gauge has visibly improved as well. The data shown there doesn't match what's in the net usage stats on trip meter. IMO the graph is more feel-good than reliable.
My guess is that I'm going to land on around 2.5 in mixed driving, and back to 2.75+ on road trips like I had with the OE 21s before I swapped to the 20s. I would consistently see >350 miles in conserve on the highway with the 21s, if the winds weren't crazy.
mikehmb
mikehmb
SF Bay Area
275/60/20 - 116 XL
zefram47
Rivian R1T, Alfa Romeo 4C
275/60/20 - 116 XL
What size were you running for all-terrains, the stock 275/65R20? If so, did you have Rivian re-code for them? The stock 20s are 34" tires and the 21/22s were 33". So if you did have them re-code for the OE 20s, then your numbers are likely optimistic going back to a 33" tire since the system would see ~3% more distance than you actually travelled for the same energy use.
mikehmb
mikehmb
SF Bay Area
I'll have the car re-coded next week during a mobile service appt, so all good there. 3% brings me down to 2.8 ... which is still too early to draw conclusions from, but clearly better than 2.2.
Sequence of events:
1) Bought truck with 21" OE. Efficiency then was 2.5ish overall, with a heavy foot. GPS showed speedo was optimistic by 1-2% at the time which changed after SW updates.
2) Swapped out at 7k miles to 20" AT black (OE size - 275/65/20, stock AT tires). Truck was reprogrammed to 20" size, range estimates dropped to expected with AT.
3) 15k miles in, consistent range/efficiency, saw 2.2 for lifetime on ATs. Speedo was accurate per GPS to within 1% over lifetime.
4) Swapped to 275/60/20 Michelins - interested to do a GPS check with these to see how close to 3% off I really am.
5) Mobile service next Tuesday so speedo will be calibrated to stock size (edit: 21" stock size)
ksujeff99
Jeff
Kansas City
Financial Services
That’s crazy efficiency, regardless of tire choice on your quad. I’m at 2.2 lifetime, mostly on the factory 21s and since February on Michelin Platinums.
Good to know. I prefer appearance and all around capability of ATs. But if my commute distance changes, will have to seriously consider AS. Hope the promised user-configurable software is out by then.
SamDoe1
Minnesota
Rivian R1T, BMW M2 Comp
The real question for me is how do they perform in the snow/ice compared to the AT's.
mikehmb
mikehmb
SF Bay Area
I had the predecessor to these tires on my MDX 10 years ago, and they were outstanding in snow and ice.
That said, if I lived where packed ice was a problem for a chunk of the winter, I would absolutely go with a dedicated winter tire (not the AT).
SamDoe1
Minnesota
I'm in MN so snow/ice is absolutely a thing for almost all of the winter but the factory AT's have actually been really good in the experiences I've had so far. We run Blizzaks on my wife's Subaru (and I've run the same on previous cars I've had too) and they are better than the Pirelli's but not to the point that I'm running out to buy new rims and tires for the winter.
If I'm going to go out and get new wheels, I'm buying a set of 22's and (hopefully) those Michelin PS5S's that are allegedly coming soon and running the 20's with dedicated snows for the winter.
good2go
Dean
WY
Engineering, Dog Petting
Lots of people have a tendency to settle into more efficient driving after a while of having fun with their new car. I don't, but a lot do. Hard to make a comparison unless you are deliberately attempting to have similar driving habits and weather as a differential between your swap.
Chinna
Naren
Albany NY
RIVIAN R1S, MACH-E4X
Software developer
I ordered same model 22inchs tires for LE R1S, waiting for delivery
RoasterX
Cambria
Coffee Roaster
@mikehmb how is the road noise on the Michelins? My OE 275x65x20s are killing me with noise after 10k miles. I'm embarrassed to take friends for a ride in the truck with this howl!
jeeden
Jeremy
Northern VA
Project Manager
The Defenders are known for being so good in an AS format that they have outperformed many ATs and even some snow tires. Check out youtube (the video is on the forum somewhere too) where a review of the original defenders were tested and really performed well
