tragicmonkey049
Erik
Chelan County, Washington
2023 R1S; 2023 Chevy Bolt
Curmudgeon
1.97 mi/kWh. Seattle to Whistler BC on 23DEC2024 in our Gen1 R1S.
Yakima SkyBox on the rear two rail mounts and a Tyger ski rack in the hitch with 3 pairs of skis in it. Stock 20" Scorpion AT tires.
Kept the top speed mostly at 65 mph on the freeways. Roads were dry until close to Whistler. Stopped to charge at an EVgo in Bellingham, and then again at the Tesla Supercharger in Squamish. Didn't need to charge twice, but did need to stop twice anyway to stretch legs and get snacks. A super-smooth trip! And there seems to be plenty of charging infrastructure here in Whistler, though I'm doing most of my charging at the rented house with my portable charger.
Rivian R1T R1S Better than expected efficiency - rooftop box & ski rack on R1S (Gen 1) 1000009364
flush
Bellevue, WA
R1S LE El Cap
tech
nice, i start at 100% from Bellevue, make lunch pit stop in Vancouver and normally charge 1x in Squamish, at the EA chargers (350kW!) across from the London Drugs (same area as the Tesla SC).
I find that i use 25%-30%ish from Squamish (Garibaldi Village) to Whistler Village given the elevation change.
I don't use a cargo box since i do a lot of underground parking - where the vehicle height limits are ridiculous.
S.Mueller
Steve
Valencia, CA
2023 R1S RB 20’s, 2022 Ioniq5 SEL
Any chance you have a link for that ski rack?
SASSquatch
Washington DC
BMW i3s Ford C-Max Hybrid
Semi-Autonomous Yeti
I've been extremely happy with the INNO BRM202ST roof box. Built really well, uses a memory clamp design so you set it one time and you don't have to mess with it again, and more importantly only resulted in a .4 mi/kWh reduction (3.5 vs 3.1) vs another trip without out it in similar weather when mounted onto our GV60 using factory crossbars on a 200 mile road trip.
https://www.rei.com/product/209163/inno-brm2020st-roof-box?redirect-pup=false
tragicmonkey049
tragicmonkey049
Erik
Curmudgeon
tragicmonkey049
tragicmonkey049
Erik
Curmudgeon
Link added in thread. If all your skis are wide, you might only be able to fit 4 pairs in...
KootenayEV
Andrew
Nelson, BC
R1T, Tesla Model 3
Environmental Engineer
That's better than I get with my truck - I'm wondering if it is because you are able to mount the box further back so the air flows up and around it better. My box sticks out over the windshield a bit. I've got some "u-bolts" on order that will allow me to move it down over my truck box to see how much that helps.
Cascadian
Steve
Volt, Outback
That’s good. Keeping to 65 max helps a lot and I think fast charging warms the battery and aids efficiency too.
I did it without box or rack, but went up to 75 on freeway and made it from NW Seattle to Whistler (220 miles) with 20 miles left.
I tried the new Tesla SC at Market Place, but stopped after 10 minutes as it is pretty expensive. I charged much cheaper on L2 during stay.
On way home the navigation seemed to be very conservative and said I would not make it home. I stopped for 5 minutes at new Tesla SC just south of truck crossing with just 25 miles added according to vehicle. However after just a short while on freeway the estimated miles at destination kept going up. I arrived home with 50 miles so I didn’t really need that stop.
ThirteenElectrics
R1S, R1T, XC40 Recharge
I stopped using ski racks due to the corrosion; I now use a Thule Alpine Motion XT with skis stacked upon each other. Nice efficiency, I don't think I've ever been able to achieve that to Whistler, but I also run snow tires.
POLAR1S
Daniel
Los Angeles, CA
2025 Rivian R1S
Isn't it better the other way around for efficiency?
I got 1.48 mi/kwh from los angeles, ca to mammoth. 300 miles. 7000ft elevation.
Gen 2 R1S DMP 20AT
Have skiis strapped onto cross bars ( no mount. super aero)
Yakima exo swing in the back.
Rivian R1T R1S Better than expected efficiency - rooftop box & ski rack on R1S (Gen 1) PXL_20241230_072800514.NIGHT
