3rd party wall chargers ok or not?
Well, heck. It is very robust, though. Not like the cheap $15 ones.
True, but there is a reason Hubble is the most highly recommended option. Plus, Hubble is made in the USA, while Leviton is made in China.
beatle
Springfield, VA
The temperature rating isn't nearly as important as the terminal quality. This one was rated for 75C.
Rivian R1T R1S 3rd party wall chargers ok or not? 20220302_211915
It used standard Phillips screws which limited how much torque you could put on them without the driver camming out. I leaned on them and tightened them down as hard as I could, but they still heat cycled themselves loose after 2 1/2 years.
Rivian R1T R1S 3rd party wall chargers ok or not? 20220302_212035
The hex socket screws on the EV-rated receptacle let you put a torque wrench on them:
Rivian R1T R1S 3rd party wall chargers ok or not? 1767309300762-vx
They're supposed to be torqued to 75 inch pounds which doesn't sound like much, but you really can't get a lot of torque out of a screwdriver.
Eeyore
Bruce
Retired Union Electrician
The Tesla is outside and I wish it had a feature to only allow authorized vehicles. It has that feature for authorized Tesla vehicles only.
Assuming that authorized people would also have access to the circuit breaker that powers the tesla charger, you could just turn it off when you aren't using it.
Time2Roll
2026 R1S Quad - 2001 F150
the Tesla is outside and I wish it had a feature to only allow authorized vehicles. It has that feature for authorized Tesla vehicles only.
Tesla collects the VIN from Tesla vehicles. I assume the issue is with other makes of vehicles not providing this communication.
Rade
Rade
US - Rhode Island
radmorningcoffee.blogspot.com
When I got my RIvian over a year ago, I ignored the advice of this forum and went for one of the cheaper L2 chargers I could find; I think I paid about $90 for it. It technically worked, but it frequently had communications issues with the truck, especially after plugging it in after a DCFC session. I decided to just used the Rivian supplied L2 charger for home, and that knock-off is now relegated to the R1T's storage bunker as a traveling emergency unit.
I think if I had to do it over again, I would have just shelled out the $400 for the Rivian model and been done with it
Coj
Christian
Connecticut
R1T, XC90 T8
Real Estate
I see wall chargers for $200ish bucks. They look nice but rivian chargers are 5 to 700 bucks. Are they that much better?
Hi, you will want a wall charger that has an app, scheduling ability and solid communication with your vehicle. We have had two ChargePoints and both lasted five years. You want a solid construction of the base and cord to mount on your wall. Finally make sure they are certified and reputable.
John.S
Nor Cal
2025 R1S Forest Green Dual Performance Large
I got a Tesla Hardwired Wall charger with an adapler as I have a 25 R1S. No issues so far but I am only 7 Months in...
