48A vs. 40A for home charging??
What amperage do you recommend for home charging an R1S?
  • Total voters
    230
ElGuano
Cali
So I when with 50A with a NEMA-14-50 connected to a Juicebox. I get 48v, which gives me 20-25 miles per hour according to the Rivian app. However, from 25% to 85% it takes 10 to 12 hours. Is this normal? or is this slow?
When you say 50A, do you mean breaker? I think most plug-in (14-50) EVSEs won't do 48A charging, so your breaker is sized correctly for 40A charging, but it seems you are charging at 48A which needs a 60A breaker and hardwired. It may be worth double-checking your settings.
You need to drop the draw to 40 amps on a 50 amp circuit. For continuous draws like EV charging you need to only draw 80% of the circuit size.
@48 amps that charge rate is normal, at 40amps you will probably be between 19 and 21 miles an hour.
Green Mean Machine
Michael
Gainesville
www.ppsnow.com
23 R1T Quad, 20 Lotus Evora GT, 02 BMW Z3, 13 Audi A6 3.0T&11 Q5, 18 RAV4
Lead PDM, Engineer, Inventor
Thank you both. I have check and the breaker is 50A. I also adjusted to draw 80%. Im not in the rush charging full speed (48) and overloading the circuit. :)
