ACDC
Michael
Portland OR
2013 Outback, 2012 Tacoma
Hest Foamy memory foam mattress for the R2 announced.
Description:
Turn your Rivian R2 into a mobile bedroom. The Foamy For R2 by HEST is a custom-fit memory foam mattress designed specifically for the Rivian R2, giving you a comfortable, road-ready sleep system wherever you park.
In this video, we walk through setup, features, and what it's like to sleep in the back of the R2 with the Foamy.
🔑 Key Features:
— Two layers of temperature-resilient memory foam
— Waterproof lower construction for outdoor durability
— Headrest attachment anchors to front seats for a flat, gap-free sleeping surface
— Rolls compact with integrated compression harness — fits in the frunk
— Linking clips connect two mattresses for a full double bed
📐 Designed to fit the Rivian R2 interior precisely. Sold as a single mattress (driver or passenger side). Two required for the full sleeping area.
Perfect for overlanding, car camping, road trips, and trailhead overnights in your Rivian R2.
https://hest.com/products/foamy-for-r2
Harvest
Columbia, MO
Honda Pilot, Rivian R1T Adventure Forest Green
agriculture
It looks like from the photos the mattress slants up significantly near the head area. I wonder how uncomfortable that would be for sleeping on? If I were going to sleep more than once back there I think I'd want to take a sheet of 1/2 inch finish grade plywood (like birch) and use some cross pieces of lumber to make a completely flat base for the mattress. The downside would be restricting the ability to fold up the second row of seats if using a single piece of plywood up to 78 inches long, but the wood base could be made in two or three sections to allow it to be easier to remove and stack.
CharonPDX
Charon
Cascadia
InfoSec Geek
Well, the same thing for R1S is $359 per side, so $718 for the "full width" pair.
