Quattro Powers
QP
Florida
Tesla
I ordered a heavy-duty extension cord for this purpose. The cord was delivered prior to Hurricane Ian. The R1T arrived after the storm. Luckily I didn’t lose power.
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
Good to see that power from the bed outlets can run two refrigerators.
I need to think more about this, the distance from the garage to the kitchen is quite a bit.
zipzag
Chicago
Model Y
I think its good to have one good heavy guage (12 or 14g) extension cord for this sort of use. In theory two refrigerators could trip a 15A breaker with simultaneous motor starts, but I've never seen that happen in practice.
Related is considering what heavy duty adapters and cords you might want for remote charging.
Count Orlok
Wisconsin & New Mexico
Just wait till you see what a Powerboost can do... (as long as you have fuel)
BigSkies
R1T, Model Y
My refrigerator maxes out at about a 3.5amp draw. A lot of the modern ones run at a lower wattage for a longer period of time. The older ones can draw more for a shorter period of time.
As long as your refrigerator is fairly modern, you’re probably okay powering more than one.
A home energy monitor is a good investment if you plan to do a lot of V2L. Having an intuitive idea of how much each device draws is helpful.
Deacon
Ernie
North Carolina
Subaru Forester, Rivian R1T
I am planning to do the same since I am in hurricane prone area. Also looking forward to v2h. Thanks for the video.
crashmtb
Man oh Manitoba
It has one major, major downside, which is recurring visits to a ford dealership.
Count Orlok
not in my case. ymmv.
Then again, at least there are dealership service options within 3 hours unlike the Towvian, I mean Rivian.
crashmtb
Man oh Manitoba
going to the dealer for routine service is an example of recurring visits. And going to dealerships suuucks.
zymolysis
Ross
Phoenix Arizona
third party service
"...maxes out at...3.5amp"
Actually, that is a misunderstanding of how refrigeration systems work. The compressor can pull a surge current (at start up) that is five or ten times what it is when running normally. An extension cord that is too long or too small a gauge can cause the starting time of that surge to lengthen, or even to fail, causing multiple hard starts. You should be choosing your extension cord with the surge current in mind.
BourboNole
Orlando, FL
Forest Green/Forest Edge R1T on 21s
I didn't even think to share it here but I ran 2 fridges during Hurricane Ian, each off a separate outlet, with no problems. I was a bit concerned by the 15 amp breaker but I realized that is probably per outlet. I only kept them on there for a couple hours until I had time to get my generator out and running, but I had no issues and love passing along the story to my friends who didn't have either an EV or a generator.
BigSkies
R1T, Model Y
While true, it varies heavily by refrigerator brand and type. I have mine closely tracked on a home energy monitor. Surge current caps out at 500W for roughly a second, and might run at a peak of 373W for about 10 minutes. Most of the time it hums along at about 130W. This is a decent example of a more modern refrigerator. I'd be comfortable putting two of these on a 15amp circuit in an emergency backup situation.
My old chest freezer has more of what you're talking about on the other hand. It has a surge current of about 785W, but mostly runs at around 50W.
I'd say that understanding what you own becomes more important as you're talking about adding more devices to a single backup source.
zymolysis
Ross
Phoenix Arizona
third party service
Yes, it does vary widely. I do work on small refrigerated lab equipment (cryostats, incubators, refrigerators, freezers, cold plates, etc.). I have often used a Fluke peak reading TRMS meter with a current clamp on these, to observe peak currents at start up. While the peak surge currents on your refrigerators may indeed be much lower than what I see on the equipment on which I work, I suspect that the actual currents are much higher than what your home energy monitor is telling you (it is probably giving you an average over a short period of time, perhaps a second, but not a true peak). The physics is still the same, though - use the shortest and largest extension cord you can - not because the stable running current is exceeds the rating of the smaller/longer cord, but because the surge currents on compressors can be very high. This will help keep the surge peak short. Note that this can increase as the device ages. What was fine when it was only one year old may not be fine when it is five years old - it may take more current to overcome worn bearings, etc. Check the locked rotor current rating (LRA) on the compressor, in order to understand what the maximum of the device is.
