Bluetooth problems
MTVhike
northern NY
2023 R1T, plus an ICE (2008 Volvo XC70)
retired scientist
How do I access my R1T when my phone's bluetooth is dead? The card doesn't work, either.
Card uses NFC and should work without Bluetooth. Also, the app can connect to the vehicle over LTE if both have reception.
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
Are you tapping the card on the driver's door handle to unlock? It's not a proximity function like your phone or the fob, it needs to be tapped to the vehicle.
MTVhike
northern NY
retired scientist
Several updates ago my card did work, but I haven't used it since then. Yes, I've tried tapping it on the driver's door handle, but I'm not sure if I have exactly the right spot.
VSG
R1T LE/RB/OC/20
Maybe it's not a Bluetooth problem, maybe your 12v is dead. It sounds like you're asking the wrong question.
MTVhike
northern NY
retired scientist
Can I even drive with no 12V? My BT is now working.
VSG
R1T LE/RB/OC/20
No, but since you couldn't get in your car how would you know?
Also, 12V could be failing - low voltage causes weird problems.
tate16t
Robert
2023 El Cap Granite R1S
Car Enthusiast
It tells you where the tap it on the back of the card.
