runningdenver
this video shows both motors next to each other, so you can see the size difference. He also explains how they work etc.
This picture shows the disassembled motors as well to see their internal size comparison. But, unfortunately, I didn't put them next to each other directly. I believe the Enduro was just a little bigger rotor and casing (not the technical names). Although, I suspect Munro's tear down did actually put them next to each other, I'd have to go back and check.this video shows both motors next to each other, so you can see the size difference. He also explains how they work etc.
Thank you for sharing. I had not read this yet.Per the CFO Claire McDonough:
Major changes on the horizon
As indicated before, Rivian is preparing to apply some changes to the R1-series EVs. The CFO said the factory will "experience some downtime" in the summer of 2024, which will be used to simplify the pickup truck and the SUV. The Irvine-based manufacturer is moving onto a simpler network architecture that reduces the number of parts (mainly ECUs) needed by about 60%. That allows the brand to also shorten the wiring harnesses by around 25%.
The R1T and R1S will get new batteries boasting the lithium iron phosphate chemistry. They have a lower energy density, but these energy storage units are considered safer because they are more durable and don't start wildly burning when interacting with oxygen. That's great news for those who often use DC fast chargers.
