Car wash foam cannon recommendations
Airmoses
Sean
New York
R1S Quad
Im looking for any recommendations on soap for my foam cannon. I have been using a giraffe tools power washer with de-ionizing water filter with fantastic results, I dont even have to towel dry. Im just looking for a better soap the with really make a thick layer and remove dirt without hand scrubbing.
Here is my setup:
Rivian R1T R1S Car wash foam cannon recommendations IMG_9817
MidnightRivian
I use chemical guys soap and their foam cannon. Just get the ratio right so you get thick suds and I let it stay on for 3-4 minutes to help pull / lift the dirt off
I do one foam cannon wash and rinse and if it’s really bad I will do another foam cannon and follow up with hand mitt.
Rivian R1T R1S Car wash foam cannon recommendations IMG_4530
Rivian R1T R1S Car wash foam cannon recommendations IMG_4529
Rivian R1T R1S Car wash foam cannon recommendations IMG_1640
Rivian R1T R1S Car wash foam cannon recommendations IMG_7019
Electrified Outdoors
Mount Airy, Maryland
EVoutdoors.org
Real Estate
I second the chemical guys recommendation! I put in 4oz of maxi suds II in my foam cannon for each wash. I don't have the deionizer but I do have water treatment on my home which balances the PH and removes hardness from the water. If I have to wash in the sun I just make sure I keep the whole truck wet (may be hard in some location like CA, AZ, etc). Once I rinse I quickly blow it dry.
I like the grape scent but they also have cherry as well. It has great gloss enhancers and a gallon of it lasts for a while.
I have all the detailing supplies I use on my Amazon store. I am pretty OCD when it comes to detailing for sure.
Essential Detailing Supplies https://www.amazon.com/shop/electri...doutdoors_QX1N1WBBMSTJEBENYS3G&language=en_US
Rivian R1T R1S Car wash foam cannon recommendations d2e23548-0630-40d8-a46a-af9f8aa94f14-1_all_31464
Rivian R1T R1S Car wash foam cannon recommendations PXL_20230708_022055903
dradam
This post led me to Adams polishes. I thought the analysis was well done. A friend likes the products and his car looks amazing. I will be applying the ceramic graphene next weekend.
Hope this helps
Redline
Edina, MN
I was using CARPRO reset before getting a foam cannon as my installer highly recommended it after I got the R1S ceramic coated. I was blown away by how well it worked in the foam cannon. Like I was meh on the suds before hand, but it performed excellent with my cannon.
Airmoses
Sean
New York
R1S Quad
I highly recommend the de-ionizer, I have water filtration on the house as well, but this removes all minerals not just scale. So the you dont have to towel dry, there are zero water spots on the car.
shrink
You have a really nice setup! Well done.
I use a CRSpotless ionizer system on wheels. Pain in the butt to move around. It’s very effective but the water in Phoenix is very hard. The cartridge resin unfortunately doesn’t last that long. Regardless, it’s a must have for me.
From browsing the auto detailing sub at Reddit, a lot of folks there really dislike Chemical Guys stuff. Not exactly sure why, but I’ve read a lot of negative comments over there. I’ve used a few Chemical Guys products and have had no complaints personally.
I think I read (again on Reddit for whatever that’s worth) that the MJJC is the gold standard of foam cannons. It’s pretty expensive. I’m guessing there are many other more affordable options that will do a fine job.
https://a.co/d/05h2NaSf
EVoutdoors.org
Real Estate
The only complaint I have about CG is the sprayers are junk. Otherwise I have been very happy with their products.
I especially like the air freshener, ceramic interior spray, and the maxi suds wash. I also use Griots products as well.
Yeah the deionizer are good.
DRJ564
2023 R1S
MTM 22.2 with Carpro Reset here for the win. Only 2 oz of reset and I can foam the car 2 - 3 times on one fill.
Gee Bee
Guy
Vw tdi golf -chevy SSR-997 Turbo S
Design
Mtm also
cherrysuds or neo soap
five gallon pail 65.00 from distributor
Or
85.90 from Amazon
cdye12
Tampa, FL
Check out Obsessed Garage. I used to use MTM, and it is still a great option, but the Griot's Garage foam cannon is now king of the hill (in my opinion). Pair it with some Koch-Chemie Gsf, and I think you'll be pleased.
https://shorturl.at/wz6nF
wjhdrew
MN
R1S, Ioniq 5
I may need to add DI to my pressure washer too. Towel drying the R1S is very time consuming and another source of possible scratching too if you're not perfect with your washing. (and who really is 100% perfect)
To answer the post: I also use the Griot's Garage foam cannon. I didn't really want to buy something I may not like, and just went with that one despite the fairly high price point. I've been happy with it. I'm sure if I add DI water, my car washing experience will level up substantially.
André
André
Quebec, Canada
Tesla Model Y Long Range, RIVIAN R1T Quad 2024
Finances
MTM Canon 22.2 is great used with Chemical Guys Snow soap (green) to get more foam. The issue you may have is that this Girafe pressure washer (like other retail stores washers) are using very small nozzle opening to bring psi up as their pump can’t push enough gallon per minute. You need more water flow and less psi: 2 GPM with 1,000 psi with a 4.0 nozzle is way better than 1 GPM with 3,000 psi with smaller nozzles. Even worst, too much psi will damage your paint. Go see Obsessed Garage You Tube channel to learn the basics.
https://www.amazon.com/Chemical-Guy...x=chemical+guys+snow+foam,aps,102&sr=8-1&th=1
