Charger installation indoors or outdoors?
PunkRockDoc
Connecticut
Forest Green 2024 DM Large R1T, 2016 Mazda CX-9
Just wondering where most New Englanders install their chargers. Was plan I’m on putting it in my garage, but my Dad is freaking out about EV car charging tires his electrician friends have warned him about.
p3ck
Bill
Massachusettes, USA
I assume you meant fires and not tires.. I have my charger in the garage, no issue. The Rivian battery is sealed and has a decent amount of fire retardant around the cells.
I'm not worried in the slightest.
bfilippo
Benjamin
Downeast Maine
2022 Launch Edition R1S Limestone, 2026 Gen2 R1T Tri Max AT, Storm Blue
Mine is in my garage, has been there since November last year, haven't had any weird problems.
Killer95Stang
Dan
Sunny Socal
You could always install the charger inside using properly sized copper wire and then hardwired to the charger itself like it supposed to be. Then just make a passthrough for the connector plug, so you can charge the vehicle outdoors. Maybe have it go through a side wall into a weather tight box that you can coil up the charge cord into when not in use.
Hereforthesnacks
West Coast
Ford Bronco
I know plenty of people who park in garages. I haven’t heard of an incident.
dradam
I’m in Washington DC. But I’ve been charging indoors for Almost a year. No issues. I do think it’s important to be sure your electrician really knows what they’re doing. There’s a lot of confusion about the correct wiring and the correct outlets if you go plug-in. I am hardwired.
For Best battery practices i usually charge only to about 52%. And on a daily drive I usually come home at around 30 to 40. When I charge I actually charge at a very low rate even though my charger could do 48 A I’m usually at about 25. I don’t need to charge fast. I just needed to charge. I hope these things preserved the battery and also minimize the heat of charging and prevent any future risks.
R1Sky Business
Just make sure is done by one or more of your Dad's electrician friends to make sure everything is on code.
Polar
C40, LE CY R1S
I’ve charged in my garage for the last 13 years…. My house hasn’t burned down yet.
VSG
R1T LE/RB/OC/20
Does you Dad store cans of gas and gas-powered tools/vehicles inside? THAT'S something he should be freaking out about instead. Not only the fire potential but also the fumes.
His recommendation sounds like it's fear-based and misinformation-based. EVs have FAR FEWER fires than gas vehicles. IIRC gas vehicles are 10 times more likely to have a fire ... there were numbers published recently that have been cited several times in this forum.
R1TCntrlMaIzzy
Massachusetts
Computer Sci Stuff
Where are those friends getting their info from?
SSteveEV
Spencer
R1T, etc
That's great, but how many garages have you burned through?
Edit: I charge inside, outside, and anywhere I can
Polar
C40, LE CY R1S
Fair. Maybe I was just avoiding the question?
