Charging with Tesla Mobile Connector Problematic
Revelstone
Connecticut
Hello
When we received our new Rivian (R1S, 2026) it would not charge at all with our charging cable (Tesla mobile connector plugged in to a 240V socket) until we hard reset the vehicle.
Subsequently we have found charging only works if we unplug the cable first.
Interestingly, we have also found that charging the Tesla fails if it has been used on the Rivian previously - so it looks like the mobile connector has some kind of memory of the previous car it was used to charge.
Does this accord with anyone else's experience? Given all of this, we're also looking for recommendations for a (very) reasonably priced charger that will definitely work with both vehicles.
Thanks in advance!
Hello
Thanks in advance!
I use an Emporia charger, works great on my Tesla and Rivian. My charger is a J1772 and I use an adapter for the Tesla but they have a J3400 version.
You can check out a web site called State of Charge, Tom Moloughney tests a lot of chargers and rates them.
jrmbadger
R1S (Gen 1)
What version of the mobile connector are you using? If it was a pre 2021 it may not work. From wikipedia “it was not until 2021 that Tesla vehicles began supporting the expanded communications protocol that is specified as part of NACS.” Wiki Eg the communication protocol on older tesla NACS devices is different. Newer Tesla chargers support both.
TampaR1T
Paul
Land O'Lakes, FL
2023 Rivian R1T Quad Motor
I have and use a 2020 Tesla mobile connector with no problems. If you're having an issue with both cars, it's obviously likely the mobile charger...
Trinculo73
Inglewood, CA
Rivian R1T, Victory Magnum X1, Polestar 2 Launch Ed
I've got this one as well, with J1772, and use it to charge both my R1T and my wife's Polestar 2 regularly with zero issues.
Duckman
Stu
PHX
R1T, Tesla MY, Subaru Outback
Same problem here. I just traded my Gen 1 R1T for a Gen 2 R1T with NACCS port. We do not have a wall charger at our summer place. Tried to charge it with my 2018 Tesla Mobil charger. Won't work. Switched to Rivian mobile J1772 charger with the Rivian J1772 to NAACS adapter and no problem. I guess it was a good thing I kept the old Rivian mobile charger. I did leave a Tesla Tap NAACS to J1772 adapter in the truck along with the Rivian NAACS to CCS adapter. BTW, we have Tesla wall charger at our home in PHX where it easily handles both the Tesla and the Rivian. It always did, even the Gen 1 with a Tesla Tap.
