Cold weather range and battery temperature
jimk
Jim
Vermont
2022 Jaguar I-Pace; 2023 Rivian R1T
Departed at 8AM today headed from my home to Stratton Ski Resort, which is 33.5 miles away (all on 2-lane state highways), with a net elevation gain of approx 1400 feet. Car was charged to 95% but not plugged in when I departed and the outside temp was 16F. At departure, my battery temp was 27F and motors were all 32F.
At 8:48, on arrival at Stratton, outside temp was 21F, battery was 59F and motor temps had dropped to 129-140F. The car reported 72% range remaining, so I used approximately a quarter of my car's range to drive 33 miles.
Repeated the drive this morning. Outside temps were in the low 30s and I left the truck on the charger overnight. Range at departure was 98% (probably because I switched on climate 15 minutes before I departed). Range at arrival was 79%. Battery was in the mid-50s when I departed and stayed around there the whole time. Motor temps never went above the 150s.
usulio
The 16% usage from ABRP already has the elevation gain taken into account.
So the rest of 7% is for battery preconditioning and cabin heating, well also assuming tire pressure etc are at nominal conditions.
That's fine, but ABRP is just making guesses, I am trying to stick to facts. (And did you mean 17%?)
usulio
Ok, nice, 19% total battery usage instead of 33%, thanks to preheating. But also exterior temps ~16 degrees warmer this time. Good info.
DaveA
DTown3011
In my experience, cold weather below 15* absolutely crushes the battery so doing anything you can (preconditioning, etc) is very helpful. Looking forward to the new update that will allow this to be on schedule!
RexRemus
Chuck
Chicago, IL
2023 R1S
Below 20F all EV really suffer... Even Tesla with the heat pump.
Until the update here is what I recommend:
Drop charge limit to 10% below your normal charge limit. Set a reminder on your phone, go into the app 1 hour before your departure and increase charge limit at least 10%. This will charge the battery and heat it up some.
Alternatively, if you know how long it will take to charge you can set a charging schedule so that it starts charging and stops right when your ready to depart. If you want to do this, use the EV charging time calculator here:
https://www.inchcalculator.com/electric-vehicle-charging-time-calculator/
If your charging at the full 48 amps it's 11kw. This will get you pretty darn close ?
I've been doing exactly this and it works reasonably well. Though I've been setting up a schedule a bit further out and then dropping the max amperage to make it take about an hour or so - that seems to get a bit more heat in (despite the lower push of energy into the pack) vs doing it shorter/faster - as I find that you really need to nail the departure window. Having it go a bit slower/longer (intentionally make sure it's STILL charging that last bit as I'm about to leave) seems to work best. I can leave with a 50/60F degree battery most times and it only heats up to about 67 when driving so it's pretty close to "running temp" from the start
AlcesBull
Spencer
R1T, Volvo XC60
I have some anecdata here. A trip last week from Denver to Basalt (outside of Aspen, CO). This trip is 180 miles with about 12k total elevation gain.
I left my house with 93% SoC after being plugged into my 120v overnight (which trickle charges ~1.5kw/h), and I arrived with 12% SoC after no stops. It was a little hairy in the first 50 mi because range guesstimate dropped a bunch going up to the Eisenhower Tunnel, for reasons I assume were similar to what you saw. I didn't pay extremely close attention to the battery data but I did clock significant motor temps in my first 50 miles. Guesstimate leveled out on the descent. I never went faster than ~75 mph so I definitely drive slower than a lot of I70 folks.
Reading your account makes me wonder if your trip was longer if things might balance out a little? On trips just up loveland pass (~45-50 mi from home, all uphill ~5k') I seem to smoke about 30% SoC if I leave cold though, again, this is an impression because I haven't been that worried about it yet.
bc81620
Ben
2026 Dual Max R1T
Do you have a dual or quad motor? Which size battery pack? Which wheels and tires are you running? Thanks!
Epicloop
Ray
British Columbia
Electrical Contractor
Epicloop
Ray
British Columbia
Does this sound within reasonable expectations to you folks?
What is you configuration? QM/DM, Large/Max, 20"/21"22"
The numbers seem reasonable for hilly winter travel without knowing the above or average speed.
33 miles/23% = 144 miles uphill in the cod no preconditioning
66 miles/31% = 213 miles return no preconditioning
66 miles/27% = 244 miles return trip with preconditioning
RAD1
Robert
Rivian R1T Max Pack, Tesla Model S, GMC Denali XL
Now that the new update is out, I would keep my vehicle plugged in and precondition the battery. I also spend the weekends in VT. This is what I do.
jimk
Jim
Vermont
Quad motor, large, 21"
