Cool Rivian Patent/TradeMark Info
kanundrum
kanundrum
Washington, DC
I was joking with @rhuber that I'm going to add more liquid cooling to it like an old school overclocked gaming PC. Gotta one up @OutofSpecKyle.
I guess we need to break out the welder, we did Pelter cooling with metal plate connected to a mini fridge compressor with a heating element. Im going to assuming we are going past safety protocols lol.
electruck
Dallas, TX
2023 Rivian R1S
The present inventor has observed a need for an enhanced thermal management system for electric vehicles that may mitigate degradation of the vehicle range due to extremes of environmental conditions. Exemplary approaches described herein may address such needs.
According to one example, an automotive electric vehicle system includes a high voltage battery system including an enclosure, an electric powertrain system, a radiator, coolant lines that permit coolant flow between the high voltage battery system, the power train system and the radiator, one or more valves for routing coolant along the coolant lines, and a controller configured to control the valves to facilitate the flow of coolant among a plurality of different, selectable coolant flow states involving the high voltage battery system, the powertrain system, and the radiator.
According to another example, a heat transfer system for an electric vehicle includes coolant lines that permit flow of coolant between a high voltage battery system, a power train system, and a radiator. The heat transfer system also includes one or more valves for routing coolant along the coolant lines and a controller configured to control the valves to facilitate the flow of coolant among a plurality of different, selectable coolant flow states involving the high voltage battery system, the powertrain system, and the radiator. The high voltage battery system is configured to serve as a source of heat for another vehicle system.
According to yet another example a method of controlling heat flow between systems of an electric automotive vehicle includes receiving, by at least one data processor, external data to the electric vehicle and sensor data from one or more sensors of the electric vehicle. The electric vehicle includes a high voltage battery system, a powertrain system, and a radiator. A coolant flow state is determined from a plurality of different, selectable coolant flow states involving the high voltage battery system, the powertrain system, and the radiator. Output is provided to a controller to facilitate control of the coolant flow state.
Sounds a lot like conditioning, heat control/extraction to me where it can take that stored heat/energy and route it to where it needs to go (High Voltage Batteries) @SeaGeo. The beginings of the idea of "pre-conditioning".
So is this new application materially different than this one from 2018? Or just an update? I'm not that familiar with the patent process and haven't had a chance to diff the content.
https://patentimages.storage.googleapis.com/df/70/fe/eef47fb7d90bc6/US20180086224A1.pdf
kanundrum
kanundrum
Washington, DC
Autolycus
ATL
ICE only :(
Gotta make sure to include some cold cathode lights all around your Rivian if you do that!
av8or
Randall
FedEx Retired
? would like to hear more about this tailgate.
kanundrum
kanundrum
Washington, DC
EDV Manual + Keyfob Pics
Funny how the EDV has proximity unlock for the FOB...
It looks like the EDV and the R1T use the exact same XMM (Experience Management Module) TCM (Telematics Control Module) and VAS (Vehicle Access System), at least their FCC and IC numbers are the same...
kanundrum
kanundrum
Washington, DC
Yeap a lot of shared devices and same VIN for R1T letters as well 7FC for amazon vans because its built on R1T chassis.
kneebuster
Joel
Golden, Colorado
'22 Hyundai Tucson Plug-in Hybrid
Professor
My FOB was DOA, but I suspect it has proximity and that Rivian just hasn't turned it on. The vehicle knows if the FOB is inside (as reported elsewhere) so it's got to be transmitting some sort of signal.
