Supratachophobia
Ohio
S
So everything is great. 7 weeks into ownership of Gen2, and certainly some software bugs. But it is what it is. Now onto the nagging question...
I would have liked to have had premium audio on the shop audio, but it wasn't in the cards for what was available and for what it cost.
Piecing together some other subwoofer threads, I think I found the elusive pink trailer wire for power so that's a solved problem. But I also found what I think is the unused subwoofer signal wire. I'm going to see if it's actually passing any audio through it.
Rivian R1T R1S Diving Into Gen2 Standard Audio to Add a Subwoofer P_20240828_203849
Rivian R1T R1S Diving Into Gen2 Standard Audio to Add a Subwoofer P_20240828_203813
Under the driver's seat does not seem to have an amplifier like in another thread. There is a box with lots of scary orange wires. And on the passenger side, there's something labeled "CSB Energy" and "ABS". If anyone has ideas where the factory amp might be, I'd like to find the other end of that subwoofer connector....
Whale Blubber
Austin
2019 BMW X3 3.0si, 2021 Toyota RAV4 XLE
Don't know if this is helpful to you, but here's a bunch of threads I was tracking when considering my hardware upgrade (which never happened):
Rivian R1 Sound System Upgrade - Social Media Posts
https://s00n.rivianstories.com/posts/stock-subwoofer-upgrade
https://www.rivianforums.com/forum/threads/completed-speaker-sub-upgrade-in-rivian-r1s.22815/
https://www.rivianforums.com/forum/attachments/audio-harness-pdf.59599/ {pdf of audio harness)
https://www.rivianforums.com/forum/...ivers-seat-and-speaker-harness-pinnout.17077/ (thread on audio harness and seat teardown)
https://www.rivianforums.com/forum/attachments/battery-pdf.61669/ (pdf of battery (two battery))
fjfilips
Frank
Torrance
Same here, R1S in the way without premium audio. Would love to plug and play a sub.
Supratachophobia
Ohio
S
Lots of responses already! Looks like Gen2 might be a totally new beast. I've read through the threads mentioned (thank you), and it looks like things are located in different places the gen2. Going to see if that connector has an audio signal.
Davethadog
YaMa
Trucks, bikes, excavators
It’s very possible that there is no amp and that the infotainment “headunit” handles the the output. The harness is totally new for gen 2, the goldmine would be if you could find an unused signal sitting dormant.
Supratachophobia
Ohio
S
I have to believe there's an amp somewhere since it was pretty confirmed the MCU didn't change.
But for the audio signal, I know, right?
BrianB
Conroe, TX
2025 R1S
I’m rooting for you to figure this out!!
Kylechoffman
San Diego, CA
'25 R1S Dual Max, '24 Model Y LR w/ Boost, '18 Model 3 LR, '06 XC90
Salesforce
Following and happy to contribute
Supratachophobia
Ohio
S
Just got word from a reliable source that shall always remain nameless, that the new location for the non-premium audio amp is under the passenger side dash. Didn't get confirmation that premium had moved there yet, but my gut says yes.
Supratachophobia
Ohio
S
Hey buddy..... Whatcha doing hiding up here?
Rivian R1T R1S Diving Into Gen2 Standard Audio to Add a Subwoofer P_20240829_012006
This is up under the passenger side dash. Orientation is connectors going up into the amplifier. Someone who isn't colorblind, can you find the two wires from the picture in the original post, in this picture?
Not sure what this means, but maybe the amps are the same between premium audio/standard, and it's just software/processing plus extra physical speakers that make up the difference?
I would be hesitant to physically cut the sub wires here since that's permanent. But this would also be an excellent place to tap an output to a wire than already runs back to *exactly* where you need it.
Last question to throw out there, are we thinking the crossover is done through software or hardware? If software, then a full range tap would need to be on a door speaker. But if hardware at the speaker, it could be done at any speaker.
Whale Blubber
Austin
Wouldn't it be nice if the OEM had an electrical diagram or workshop manual available so people could work on the cars without having to reverse engineer them first?
BrianB
Conroe, TX
2025 R1S
Seriously though, are you able to see if those wires match between the two pictures? I can't tell colors.
Seriously, it’s a lot of purple/white wires. In a static photo, where I can’t see both sides of the wire, I couldn’t tell which match well enough that I would cut anything.
