VSG
With a Nov 2020 R1S pre-order, the only reason you wouldn't have it by now is because of your configuration (you want something they're not making anymore, or not making yet), or because of your location (you live somewhere they're not delivering to yet).November 2020 preorder
The non-wood interior wasn't an option until the middle of 2022, so at some point you changed your configuration. I don't know what it was before that, but when you switched to the non-wood interior you essentially got into a different line, and that line wasn't moving because they hadn't started to manufacture that trim yet. If you had an Explore Edition configured previously, that would be another reason you're at the end of a line - Explore was always schedule to ship after Launch Edition and Adventure Edition.maybe ocean coast is being discontinued in favor of ocean coast + dark wood trim only
In fact, in August 2023 Rivian said they weren't going to make the non-wood trim because they didn't have many people who wanted it. There was an email sent out - not sure if you got that. I've always found the names of the trims confusing because "Ocean Coast" for example originally meant the wood-trim version, then they renamed it and "Ocean Coast" referred to only the non-wood trim version. Communications from Rivian, and posts here in the forum, that refer to "Ocean Coast" are often ambiguous about what they're talking about (to me at least) unless they explicitly mention wood. So to be clear, the wood-trim interiors, including Ocean Coast w/ Dark Ash, are still being made and will continue to be made, while the interiors without the wood are not going to be made. (I believe a few of the non-wood interiors in Black Mountain were delivered, but that was just a few before they decided they weren't going to do that.)
I think if you had a wood trim interior you would have had your vehicle by now. But with a non-wood trim interior you are now on an indefinite wait list.
Bottom line, if you want an R1S, you will have to pick a different configuration. If you switch to a different configuration or choose one out of the shop, you should have it by the end of the year.
