Fclmd
Fawn
Tulsa, OK
R1T, Kia Telluride
I like the “granola” holder.
Not sure about aluminum metallic look.
A rubberized surface for charging will keep the phones from sliding on the MagSafe charging surface. Right now the charging pad is unusable in the R1T because the moment you hit the accelerator, the phone slides off of the charging point.
Two usable MagSafe chargers are a must!
zefram47
Rivian R1T, Alfa Romeo 4C
Agree! Definitely need 2 MagSafe chargers that work and a surface that holds the phone against sliding.
The current charging surface is not usable because it’s difficult to find the right position for the phone and the first time you hit the accelerator or brake it’s no longer charging. I have to plug my phone in.
At least for newer iPhones the slippery factor doesn't matter since they'll be held to the charger with the MagSafe magnets. But for older iPhones or Android it would obviously matter. Qi2 spec should see magnets getting added to Android phones in the near future as well.
Sojhinn
Sojhinn
2019 Tacoma
Teacher
Hey all here's a quick update on the prototype in the truck. I have a prototype going (all 3d printed currently). And I am happy to say its working great. I'm fairly certain this will be the "final" design. Just waiting on the premium plates to show up (February 6th currently estimated) to show off our choice of softness.
I'm happy to answer any questions. As a reminder this will utilize the OEM connector for charging the magsafe pucks (with the actual oem connector on our buck charger), the charger is held in place utilizing oem connection points and doesn't require any special removal to lift your phones off the chargers, and is made to look as OEM as possible.
TheLTrain
Leyen
Pleasanton, CA
Tesla Model S, Ford Escape Hybrid
What is the install process like? Will this be very complicated?
Sojhinn
Sojhinn
2019 Tacoma
Teacher
Remove rubber mat, remove oem charger (3 prongs that hold it in, more annoying than hard), slide in our base, slide in plate (this requires a specific way, but it's not hard at all), once the plate is lined up with the chargers... push down. It clicks in place and you are done.
windblowlc
Loc
WV
Still the cleanest and best looking pad. ?
Sojhinn
Sojhinn
2019 Tacoma
Teacher
I REALLY appreciate that. I've worked really hard to make things look like they belong in the truck. And I try really hard to make as many of you as happy as possible. If it wasn't for this forums feedback I wouldn't have spent the time looking for the new plate material.
kylealden
Kyle
Product Management
Super super interested in this one. Is there a website where we can preorder?
Sojhinn
Sojhinn
2019 Tacoma
Teacher
s00nish.com will be where you can preorder it. But I am waiting on the final plate material. That will decide our cost.
edit: that's two zeros
TheLTrain
Leyen
Pleasanton, CA
Awesome, looking forward to this!
bhlackey
San Diego
R1T G1, KTM SX-450F
Love the progress here! Will you support Apple pucks? as they are the only ones that charge at 15W. all others only 7.5.
Sojhinn
Sojhinn
2019 Tacoma
Teacher
Yup that's whats attached to my truck right now. Also our buck charger that connects to the OEM connector supports 15 watts to each puck as well.
Leonbmx
2022 Rivian R1T, 2020 Tesla MY
Boeing Design Engineer
Nice!
So, just to make sure I am up to speed on the latest info - the part in the pic is not flush with the wood trim, because a top plate of tbd material will take that space, correct?
And the pucks will be under that material and therefor not visible? I personally don't mind either way, just curious.
Sojhinn
Sojhinn
2019 Tacoma
Teacher
Nice!
Nope. On testing we found that if went above there were issues with fit across different trucks. We also didn't like our mounting methods when we tried lifting the phones.
This would be similar to what you saw at the off road event. It looks really clean in person and gives more clearance for phones.
