Gen2 Max Pack R1T Range (AT tires)
brandoncole
Brandon
‘26 R1S Dual Max
Bummer. Maybe you can sell the gently used tires when the time comes.
I plan to keep mine until Spring and swap the OEM Perelli for the Michelin Defender LTX or the Nokian Ones to get that 22” efficiency 3 out of 4 seasons.
loubendor
Louis
Bend, OR
2025 R1S
Hi, happy New Year to all.
Yes, those are the Goodyear tires designed specifically for Rivian.
It’s definitely worth asking Rivian if they can swap the Goodyear tires onto a Max Pack configuration.
Keep us in the loop. Hopefully, it works out.
These Goodyear tires are 275/60 vs 275/65 for stock AT tires. Diameter is 32.9” vs stock 34”. I would expect that would impact range. Can the Rivian accommodate for the size difference in computing speed, battery and range estimates??
mkhuffman
Yes.
Did you know the Goodyear tires are Rivian OEM specific tires? Did you know you can change the tire size in the settings? When you do that, the truck adapts and provides range estimates based on the wheel/tire selected.
loubendor
Louis
Bend, OR
2025 R1S
No, didn’t know the tire info was configurable. That’s why I read this forum - always learning something new. Thanks for the info. The Goodyear’s look like a great tire.
tpepper
I get about 365mi with max pack and OEM Pirelli 20” ATs. Doesn’t seem to matter much if that is 70mph freeway or more basic driving.
bfilippo
bfilippo
Benjamin
Downeast Maine
2022 Launch Edition R1S Limestone, 2026 Gen2 R1T Tri Max AT, Storm Blue
Helpful, thanks!
