GOAT Fabrication Rock Sliders (R1S and R1T Available!)
San Francisco, CA
I'm not so sure this is true. I have these GOAT sliders on our R1S and just had it in to the Rivian service center where they did a balance, rotate, and alignment for me. No questions asked and they didn't say anything about the sliders.
that would be great! My appointment with them for balancing, rotating and alignment is in May at the South San Francisco center. I can let you know what they say then. Their support number has said that if their pucks wont fit they wont rotate and require me to remove the sliders before bringing it in. They wont remove the sliders and reinstall them to rotate the tires.
Let see what happens when I actually take the car in for these services.
Adam re-worked the R1S sliders that we had on my vehicle to clearance in for the jacking puck. He said these were the biggest ones he could find. Anything ordered going forward will have this clearance designed into it. He said it shouldn't affect the overall strength of the sliders.
If anyone is worried about the set that they already have, he said to reach out to him to figure out the best course of action for you.
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) 1708099000761
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) 1708099066052
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) 1708099103946
Just my opinion, better to mill down pucks than to make slider gusset smaller. Takes a machinist less than 30 mins on a mill to do two.
Adam told me he might offer a set of modified pucks for those that were just looking for a solution.
IMO the metal for the slider brackets is already way thicker than it "needs" to be. The R1S slider has the same number of brackets as the R1T but this last one is just quite a bit farther forward. It's going to distribute the weight if there was any sort of a weakness, which I don't think there is. Adam suggested he could have just eliminated it entirely, but opted not to.
For comparison's sake:
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) 1708102993884
If you watched the video they took of my R1T dropping on the sliders, you can see that I came down on the front pretty hard, which has a ton of overhang and handled it just fine.
Si.LE.R1S
Chad
Las Vegas
‘23 R1S Launch Edition, ‘20 eTron Chronos Edition
Just an FYI. Jack puck interference is only relevant if you reinstall the plastic covers. The pucks simply allow lifting without having to remove the plastic panels.
If you leave the covers off, the entire exposed area around the jack point on the frame is safe for lifting. See manual excerpt.
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) 1708115342070
Also, the Rivian adapter in the spare kit has a smaller diameter than my aftermarket pucks and might fit (I don’t have the sliders yet to test).
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_6015
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_6017
Having said that, I plan to re-install the plastic covers as @blah_blah_blah-415 did, so I’m happy this being addressed.
Prior to the sliders, I had just been lifting against a 2x4 directly against the frame. Bolt heads deform the board and hold it in place.
For sure it's going to be important to be able to use the spare jack as expected. I meant to grab mine for today but can just double check it tonight. I don't have a jack in my S.
Si.LE.R1S
Chad
Las Vegas
Just completed R1S installation and can confirm that the revised version with the bracket cutout allows plenty of clearance for my 3rd party jack pucks and the version 1 Rivian spare kit adapter. I also have the version 2 Rivian spare kit and that has a very narrow top so will easily clear. Also, I measured the weight of each slider at 46#.
So far very pleased (10 minutes after installation🤣)
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_6296
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_6298
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_6283
shrink
Adam was awesome enough to send me a set of the revised R1S sliders.
All is good!!!
Adam is great to work with. @Dark-Fx, really appreciate your efforts in getting these designas well!
For the price, I would have gotten these for my other R1’s over the DCE’s (which are a fantastic premium product but at a premium price).
Taking this vehicle up to Sedona in a couple weeks and will hit some trails. Hopefully won’t have to put the sliders to use but super happy to have them for peace of mind on the trials.
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_1568
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_1569
Ripped
Somewhere
R1T Dual Max
I'd like to hear a little feedback from R1 owners who have had these for a while. We get a lot of salt/snow slush in the winter. I don't mind repainting any scuffed up areas due to off-roading but be great to see how they hold up after some rough weather.
Tampa R1T
Charlie
Tampa Florida
Ordered R1T sliders today from Goat.
Si.LE.R1S
Chad
Las Vegas
Ordered mine 1/27, received 2/24 in Vegas! Took my first light scrape on them today. Definitely happy with them so far, but they’ve only been on for a few weeks so not much to report.
Si.LE.R1S
Chad
Las Vegas
@Dark-Fx Do you or Adam have recommended single jack point to lift the entire side of the vehicle? I don’t think my 3-ton shop jack will cut it, but thinking of getting 5 ton bottle and a couple jack stands. I swap the tires often for trails and road trips.
Tampa R1T
Charlie
Tampa Florida
Hey, I just had them install my finished ones yesterday. I took a couple photos, but they aren't really any better than the ones GOAT took. Rained yesterday afternoon so everything's dirty today already. Quality seems great and there's a decent amount of space between the bottom of the door and the sliders, which was one of my bigger concerns here in Michigan with leaving them on year-round. Last winter season when we tested the initial piece, I had some issues with ice accumulation causing the door to get hung up a little.
I believe Adam's intention was to just give me this set for letting him use my truck to get their program going (and will also let them do the first test with our R1S but will probably not get a set for it), so full disclosure there.
I *think* he's interested in making other products for the Rivian as well, but we/they haven't done anything about other products yet. He sounded interested in doing bull-bars but it'd require a lot more disassembly and experimentation and wasn't sure about the size of the market.
I think he also wants to mock up a trim template based off my existing panels but he's out of town this week so he hasn't even seen the finished product himself yet.
Is there any update on a template for R1T?
Tampa R1T
Charlie
Tampa Florida
1 side done.
unable to get the 2nd bolt from the front to mount, so only using 4 bolts of 5. i think the threading inside was not the same as the others; bolt wouldn’t turn after only a few turns
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_0913
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_0914
Rivian R1T R1S GOAT Fabrication Rock Sliders (R1S and R1T Available!) IMG_0915
Tampa R1T
Charlie
Tampa Florida
Driver side had no issues with bolts. But I am now the 3rd owner to have issues with bolt #2 on passenger side.
Put the truck in off-road mode when removing the panels, but returned to normal mode when bolting the sliders on - because then the truck is the same height above the ground as my forearm length. That made it easier to hold.
it is a 2 person job to hold the slider in place while bolting It on.
Hardest work was cutting the panels with a carpet knife.
