kibucs
- Thread starter
- #1
Hi-
I'm on the waitlist for the R2 so starting to plan for the home charger. First time EV owner btw.
Setup: Home charger to be installed in the garage. Main electrical panel is in the basement the opposite side of the house as the garage. There's a sub panel in the basement that is underneath the garage. I'm clueless when it comes to electricity so ran it by ChatGpt to see what my options are. I have not contacted an electrician yet, just doing some research in advance.
This is ChatGpt's recommendation. Does this sound like a reasonable solution? Any suggestions are welcome.
Existing 50A feeder from main panel → subpanel → Tesla Wall Connector
The Tesla Remote Meter monitors the current being used by the subpanel. The charger then automatically adjusts the R2's charging rate based on how much capacity is available.
For example:
What you would buy
For example:
- Dryer off, washer off → R2 charges faster
- Dryer turns on → R2 charging automatically slows
- Other loads increase → charging slows further
- Loads turn off → R2 charging automatically speeds back up
What you would buy
- 1 Tesla Universal Wall Connector — the same one you found
- 1 Tesla Remote Meter — $210, specifically to enable Dynamic Power Management
- Electrical installation and commissioning
