JRE Electric Hummer Conversion Build
Ladiver
Jeff
Ca
I didn't see prices listed on their web site, so as the saying goes, "if you have to ask, you can't afford it."
I asked and will let you know. ?
kurtlikevonnegut
SC/TX
2023 R1S DM, Honda Odyssey
Watching the JRE series I think my biggest takeaway is that plug and play battery solutions have a ways to go for this to be anything other than a very boutique (and expensive) process. The crate propulsion systems from GM and Ford will help, but until there is a decent plug and play battery package that will reduce the wiring required, these projects will be super labor intensive and as expensive or moreso than simply buying a new EV.
Zach05855
Zachary
Foothills, Alberta
Jaguar I-Pace
  • SPECS
    • DUAL TESLA LARGE DRIVE UNITS
    • 0-60 MPH
      <2.9 SECONDS
    • RANGE
      UP TO 750 MILES
    • HORSEPOWER
      1272 HP
    • TORQUE
      3,987 LB-FT
    • WHEEL TORQUE
      20,898 LB-FT
    • TOWING CAPACITY
      10,000 LBS
    • GROUND CLEARANCE
      18 INCHES
    http://www.northamericanev.com
  • Price: $329,000 Firm
Ladiver
Jeff
Ca
SeaGeo
Brice
Xc60 T8
Talk about a clickbait picture for his video. I quickly clicked through just to convince myself he didn't put a super low profile tire on the hummer!
kanundrum
kanundrum
Washington, DC
I love the look and he should totally make it work that way haha
SeaGeo
Brice
Xc60 T8
He has the video up placing batteries in vehicle….
Wow! A lot of time, effort and $$$ went in to the project so far.. great results.
azbill
Bill
I just had my Bolt battery pack replaced, it is already very much plug & play. The BMS computer is inside the battery, there are three electrical connectors to the battery pack and two cooling connections. One of the GM e-crates uses the Bolt motor and battery, there is a newer one based on Ultium that is using the Lyric setup, which has a wireless BMS system. The Mach E pack is also pretty modular as well, and that is what Fords e-crate is using.
kurtlikevonnegut
SC/TX
I've heard that the Bolt and Leaf packs are the best for e-crate mods and that makes sense. I'm waiting for more details from GM in the availability and price of their ultium crate system. I'll be very interested to see what the $/kwh is.
