Launch Mode - Times
madhat
22 R1T
Probably not for 7k+ lbs pressing down on them and torque for days. Elevation, weather (wind) and air density (aero) play a role too. I don't see too many paying attention to that. There's also the road surface not being all the same.
Agree, however I don't think aero makes a substantial difference to 60. Road surface is a factor though.
I found it interesting that it seems to turn the motor cooling fans to max after the run... not a bad idea 😀
zefram47
Rivian R1T, Alfa Romeo 4C
Mine would do that in sport mode after ripping from a stoplight before launch mode was a thing too.
GrandLarseny
Daniel
Dallas, TX
Rivian R1T Quad
Well, I wanted to take a (much) better picture at the end of my run, but it totally didn't work. I did hit 2.70s in my 2026 R1T Quad. Instead, I took a couple of screenshots from the launch cam:
Rivian R1T R1S Launch Mode - Times IMG_0703
Rivian R1T R1S Launch Mode - Times IMG_0704
Battery was at 85%, battery temp was around 90. Honestly I'm new to how to get launch mode to work in general, so I'm still figuring stuff out, but maybe I can grab a better screenshot in the future?
smashweights
First real go at it. 2022 LE Quad, 44k mi, SOC 58%, cold 20" Toyo OC AT3 EV, battery 65°, air temp 70°
Rivian R1T R1S Launch Mode - Times 3944
Singletracker
NV
2023 R1T QM w/20” A/T’s
Gen 1 quad. I’m not getting the metrics after using launch mode. Am I doing something wrong. No 0-60 times showing. Suggestions?
Same problem here. I went out to give Launah Mode a run in my ‘23 R1T QM. Did three runs, but got no 0-60 times. I was pulling about .95 g’s. What’s the deal with that? One time, it showed my max speed was only 38 mph. Really?! Pretty sure I saw over 70 before I shut it down. Did you ever figure your Issue?
mkhuffman
Is "Lanah Mode" only available in Hawaii? Maybe that is the issue.
I recommend you <ctrl><alt><del>
Bean2012
Arkansas
rivian r1s
I haven’t tried again. I’ll come back here after I do. I did the hard reset.
Engineering, Dog Petting
Gotta keep the throttle all the way on the floor or it thinks you meant to stop early.
Singletracker
NV
Mine has been set and reset, for other reasons, since the addition of Launch mode. So, I don’t think resets are going to have much effect in my case. I might give it another try next week, but I don’t need to burn up my tires. Suffice to say, it is stupid fast!!
Mousetrap
San Francisco Bay Area
'22 R1T
That's one of the reasons I switched to the Michelin tires with the treadwear warranty 😆
Gurule92
19 Tesla Model X Raven & 22 R1T, Adventure, QM, Glacier White.
Cyber Stuff
New personal best: 3.16s to 60
CryThief
North Carolina
22' R1T
I'm having the same issue. Have done 3 launches. Hard resets between them and I only get Top speed and gforce. No 0-60.
