Hillbilly
I can't even sit in the Rivian when fast charging in hot weather. Always end up looking for a place to cool off.If given a choice between 150kW and 350kW I typically use the 150kW because of the thermal throttling you mentioned. I’m sure there must be a reason, but I don’t understand why the Rivian doesn’t keep the A/C on high when a DCFC session is initiated and the external temp is above 50°F or whatever makes sense. It seems like it reduces the cooling until the battery is too hot and then goes to max. This seems counterintuitive to me, but I’m not an engineer.
