Proximity off at home not working
Stickboy46
Kansas
Rivian R1T FG/FE 20" AT Dark
I don't exactly when this started but noticed in the last couple days, the proximity lock/unlock off setting for home isn't working. I have it set in the settings for off when at home but it still constantly locks and unlocks while sitting in my garage. All my other location based settings work (like garage door opener). Anyone else seeing this?
tate16t
Robert
2023 El Cap Granite R1S
Car Enthusiast
If a software reset doesn’t work, reset your home location or confirm it is set.
redantpile
allen, tx
2018 EDGE, 2023 R1S red adventure 20"
Retired telephone engineer
Agree on a reset. Mine has done the same thing, and other proximity issues. A reset fixed it. Sometimes a issue came back until the next software update, but not the presenting at home problem.
Joe Hoffman
Joe
Rancho Mirage, CA
2023 R1S & 2025 Evolution Golf cart
Retired Software Engineer
I had this problem and it was caused by the fact that my home address was set wrong. So it didn’t think I was at home.
Rivan
Rivan
Irvine
R1T, Lexus RX350, Toyota Tundra
Eng
I am having the same issue. I reset home location, however I noticed I lost garage door proximity again after a week. I had to re do that as well. I think this was part of the new update somehow some software bug is introduced.
RivAW
Alex
MA
Your “home” is set wrong either because you set it wrong, or due to a “blip”. When mine does it, the garage door opener shortcut simply stops showing up. A full reset should fix it or you can try deleting and resetting your home location (and/or toggling the proximity at home settings).
Stickboy46
Kansas
So figured it out. When i left the other day, I noticed the GPS was "Stuck". I.e. even though I left home it still showed I was at home. So when i got back home, i did the infotainment reset which allowed the gps to function again. That fixed the lock at home problem.
I'm guessing since the GPS wasn't responding, even though it said it was at home, it still triggered the proximity lock. Makes sense from a protection standpoint so people don't leave home and the truck doesn't lock in the parking lot somewhere because it still thinks its at home just because the GPS isn't responding.
Freemanc80
Collierville, TN
Rivian R1S Launch
I was having this experience, but my proximity locking/unlocking "off at home" feature never worked at home. Turns out, google had my address/coordinates incorrect in their database because it was a newer development. Originally, I discovered it when I set my garage location, and the address that populated was an address on the other side of my neighborhood. When I entered that (incorrect) address into my navigation as my home address, tada...it started working properly. So, I then submitted an address fix to google maps, which they approved. Once google corrected the address, I had to go back into my garage settings, update the location prompt, and change my home address to the correct address in navigation. Now, I have the correct address information on google, and that correct information matches in my vehicle as well. Everything works properly.
