R1S rear window wiper replacement?
ceetiger
Ed
Salem South Carolina
2023 R1S, Adventure, Limestone, Forest Edge
Has anyone had any experience replacing the read window wiper blade? Searching the forum, the best
answer I have seen is a short video on how to do this on a RAV4. But trying it on my R1S doesn't seem to
be the answer.
If anyone has a video or a good description on how to do this, I would be very grateful.
ceetiger
ceetiger
ceetiger
Ed
Thanks for this, but that doesn't answer the question about how to remove/install the blade on the rear window wiper.
I'll have to look at my replacement blade, but I purchased it in the Rivian Gear Shop, so I expect it should be the correct version.
tigercee
Windblade
Solvang, CA
Manager
I've the same question and same problem with replacement (non-Rivian) not fitting.
sub
Rivian R1S, Tesla Model 3
tigercee
The video on that link seems to show it pretty clearly.
Actually I was able to replace the blade without removing the arm. I pressed the blade to the window with one hand and used the other hand to pull the arm really hard.
Here's a video:
ceetiger
ceetiger
Ed
Thanks for posting this. I will give that a try.
ceetiger
ndmiller
Noah
Atlanta
23 R1T Silver (The AG)
Retailler
Easy once you know how to do it. Lexus GX was the same, fustrating beyond compare if you didn't know, but 5 minutes including opening the new one and tossing the old if you did.
