opnwide
R1S delivered 2/2023
The Cooper AT3's in OEM 20 sizes are 11lbs more each!! However, they have a much higher tire operating pressure range than the Scorpions. Scorpions 50PSI and the Coopers can be run up to 80PSI.
I did two runs on my 55 mile freeway test track (some grades and flats) and found that I can gain back my lost range on the Coopers by running them at 65psi, which is where I have been at for two-months. Far more durable tire over OEM. More to come...
Photos?
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
R1T Launch, R1S Canyon Red
SeaGeo
Brice
Xc60 T8
You sure they weigh that much more? Aren't the OEM tires 46 or 48 lbs? My Nokian LT3s are 54 lbs.
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
Positive. I weighed them personally. I have another thread somewhere showing the weights on a digital scale. Sidewall rubber on the Scorpion EV's are THIN.....
Armando
Napa
911 Turbo, Tundra, MBZ GLE AMG 53, 66 Mustang Conv
Winery owner
Wore out 22” Pirelli’s in 11,000 miles. Does anyone know what other 22” tires are available that will work with the R1T?
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
R1S_HYS
How to make sure there is enough space for calipers, after wheel maker agrees to build 48 offset, 9 width and 22 diameter?
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
If a manufacturer is going to build a custom wheel with all the correct dimensions from a design onwards standpoint, then they need to do the measurements on your vehicle directly.
R1S_HYS
Bpaulin6
Bruno
Chino Ca
2022 Rivian R1T
Product Development
ForeverOnTheWaitlist
B
Pacific NW
Outback, CRV
@Mark_AZR1T
Among the 20 OEM wheels, aside from cosmetics, any have a weight or construction advantage ? There was some back and forth on the previous page over the brights/darks being a lower grade of forging. Not sure the weight differences.
If you're aiming closer to ~2500/4 wheels. Any other recommendations ?
Mark_AZR1T
Mark_AZR1T
Gilbert, AZ
jackpucks.com
@Mark_AZR1T
There aren't any custom wheels that are hubcentric (no adapters) at your price point that actually have the correct specifications. I imagine there will be some in the coming weeks and months that bridge that gap.
The only forged wheels are the 20" wheels Rivian uses on the AT set-up.
graphex
Sean
Lafayette, CO
So I worked with Discount Tire to find a spare (the day before Rivian made the full size spares available) and we found this brand new wheel. Unsure if it would actually fit we tried it on a front wheel and there were no clearance issues. I’m nowhere near a wheel expert but it seems like a pretty good wheel and looks nice on the truck. I only got it as a spare but might consider getting 3 more for a full second set to have around for an alternate tire (put the exact 20” scorpions as my other tires to start).
Any thoughts or concerns from those of you out there that might know a thing or two about wheels?
Rivian R1T R1S R1T 20" AT Wheel Weight, Specs, Offset, Bolt Pattern, Construction IMG_5912
Rivian R1T R1S R1T 20" AT Wheel Weight, Specs, Offset, Bolt Pattern, Construction IMG_5911
Rivian R1T R1S R1T 20" AT Wheel Weight, Specs, Offset, Bolt Pattern, Construction IMG_5910
Rivian R1T R1S R1T 20" AT Wheel Weight, Specs, Offset, Bolt Pattern, Construction IMG_5907
