R2 efficiency
SDH
NC
R1T LE; Jeep Rubicon
Hi All,
Had anyone heard, or has Rivian disclosed, what sort of efficiency the R2 will do (roughly)? I've not seen anything but I assume its going to be better than the R1.
Cheers
kurtlikevonnegut
SC/TX
2023 R1S DM, Honda Odyssey
Hi All,
Cheers
All of the release press indicated an EPA rating of 3.75mi/kwh, a roughly 50% improvement over R1
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
There has been no announcements, but you can do some quick math from the uncovered battery size (87.5 kWh) and EPA range estimate (330 miles), you get about 3.7 mi/kWh.
I don't see that number anywhere on Rivian's site, or in their press release... is there some other place where a Rivian employee has officially stated a number?
kurtlikevonnegut
SC/TX
It was referenced in several of the videos, but the R2 site specifically states a 330 mile EPA estimated range and we know the battery size, so the rest is just math.
VandalSibs
Andrew
Yeah, but that's not "press releases are stating an EPA rating of 3.75....". That's us doing math. While it's a good and resonable guess, it's not an official number from Rivian.
Gen(R3)Xer
Ohio
This is great for a rounded box on wheels. The lower roofline, rounded rear quarter panels, and hidden aero spoiler really made a difference.
I wonder what the R3 will get with an even lower roofline and a more rounded form? Maybe 4.5mi/kWh?
VSG
R1T LE/RB/OC/20
There is no official EPA rating for the R2 yet. Rivian's estimate of what the EPA rating will be is as accurate as you're going to get, and should turn out to be very close to the official number.
Technically they said “indicated” not “stated”, I assumed their number was deduced…🤷🏻
kurtlikevonnegut
SC/TX
Syntax is important here. I specifically said "release press" not "press release."
"Release press" as in, all of the press coverage at the launch event when the information was allowed by Rivian to be released as opposed to a "press release" which is an official statement from Rivian for the press.
ElGuano
Cali
I recall from the press rides, you could see the efficiency numbers on the dash (of course those could be placeholders or artificially inflated for the purpose of the event), and they were generally in line with ~2x as efficient as an R1.
VandalSibs
Andrew
Wow, my brain reversed the two words in your post. This crazy morning at work is not helping my brain out at all...
SDH
SDH
NC
Thanks all.
In short, a decent bit better than the R1. That'll do for me!
yuanyi21
Tesla Model S
I'm a bit skeptical about the 3.7mi/kWh number, even though it's mathematically accurate - my Tesla Model S barely reaches 3.8mi/kWh, despite having a similar weight, a smaller frontal area, and a much better drag (0.208 vs 0.3).
Sure... assuming both vehicles have same platform and motor efficiency. Waste of time to speculate or cast doubt. The actual numbers will be out eventually.
