ohmman
- First Name
- Mark
- Joined
- Aug 22, 2020
- Threads
- 4
- Messages
- 109
- Reaction score
- 321
- Location
- Sonoma, California
- Vehicles
- 2022 Model Y, 2024 Model Y, 2022 Model 3
To expand a little on what @ajdelange was saying about the range forecast, there are two methods in Teslas to look at your range - the battery range status, which can be displayed in distance (mi/km) or in percentage. If you have it set to distance, it works precisely as @DucRider suggests - it takes the remaining charge in kWh and multiplies it by the EPA rated consumption number to arrive at the remaining mileage.
There is also a consumption app that shows you a chart of your consumption over the last 5, 15, or 30 miles. That app also provides an average over those miles, and tells you what your range would be if you continued that particular average, by substituting that value for the EPA consumption.
Either one of these can be either accurate or misleading, depending on how much experience you have interpreting them. If you've just climbed a long pass, the consumption graph estimate is going to be pretty far off. Likewise if you've been going downhill but have a 50 mile climb ahead of you.
These explanations are overly complex, though. Nobody really has to do any math. You can get it pretty quickly, and it's just a matter of seeing if you are consuming more than normal or less than normal to have an idea if your estimated range is accurate. If you need more range, the answer is typically simple. Slow down.
