Craigins
Craigins
Chicago Suburbs
Software engineer
oh i see now. the survey results are different from the forum thread. I did not manually compile the forum thread into the survey results. We've circulated the google survey throughout fb/reddit/forums for people to fill out. Some people fill out the forum poll and the survey, some just the forum poll, others just the survey.
SteveInBend
Steve
Bend, Oregon
2022 El Cap R1T
Unfortunately, I don't think the survey results are very reliable. Are there really 7 folks with R1S orders with LE and Max Pack who have received expected delivery windows in 2022? I thought that Rivian hadn't announced the Max Pack for the R1S. Has Rivian even announced any expected dates for the R1T with Max Pack?
It seems like some respondents have entered the dates they expect/want versus official notification from Rivian.
SeaGeo
Brice
Xc60 T8
There are clearly a few people who either selected the wrong trim or battery, or just don't know how to read. However, that's only about 2ish percent of respondents.
Mark K
Lansing
2011 Volt
I didn't remember the difference between MaxPack and Large Pack. and chose the wrong one. There is no way to go back and edit the entry and the person who set this up doesn't correct it if a change is requested.
DaveA
So I’m all alone in San Antone driving my R1T next year? ?.
EV-X Oregon
Ashland
Tesla Model 3, Volvo XC 60, BWM X5, Honda Odessey
Principal Real Estate Broker
Just so everything doesn't get lost in the mega thread with the poll, I compiled the links to the survey, the spreadsheet results, the dashboard results, and a geojson here:
https://rivian.craiginsdev.com/
I manually generate the geojson so it won't be in sync with the spreadsheet and dashboard.
Enjoy!
Just a quick edit: https://rivian.craiginsdev.com/index2.html has the clustering enabled if you want to drill down into specific areas
Not sure where you'd like to receive the data.... but thanks for doing this!
Ordered April 2019, R1S LE, LA Silver, Ocean Coast, 22"s, delivery to Ashland Oregon= May-June 2022
Craigins
Craigins
Chicago Suburbs
Software engineer
Craigins
Craigins
Chicago Suburbs
Software engineer
The only dataset that will be perfect is the dataset that Rivian has that they use to generate the delivery schedules.
All surveys contain noise. The point isn't to pick out individual records of a dataset, but to observe trends in the whole dataset. Clearly this means pruning outliers, things like you have pointed out, when doing analysis.
EV-X Oregon
Ashland
Kialoa
Kialoa
Massachusetts
911, Cayenne
Started looking at the data in the spreadsheet a bit more closely. While there is data that seems to have errors attached (LE AND MaxPack), some duplicates, and some dates typed incorrectly, there is enough to extract trends. I tried to remove most of the suspect entries and made a series of wild assumptions to see what could be learnt from the few hundred remaining data-sets. So far I focused on LE R1T data only. My thoughts so far:
1. The strongest correlation to Projected Delivery Date seems to be the Pre-Order date (Black line in Fig).
2. Within the contiguous 48 states location does not seem to play a significant role
3. Outside the Contig-48 and for Canada the delay seems to be 3-4 quarters (red line below).
4. The Exterior Color, Wheels, Spare, Off-road-Upgrade, and Accessories do not seem to play a significant role
5. Interior Color DOES seem to influence delivery dates. Black Mtn seems to be prioritized. Ocean Coast seems to have a 1-8 week delay, and Forest Edge seems to have the longest delay (4-10 weeks).
Not sure if Excel Figs are legible in this forum, but just in case they are - one of the Figs. I generated is included below. With more data - and more QC of the data - quite a few conclusions could be extracted. Even with the data in hand there is more that could be done to look at non-LE orders, and look at all the R1S data.
Rivian R1T R1S ? Rivian Delivery Window Survey Results [Data & Trend Analysis Added] survey_1-png
SeaGeo
Brice
Xc60 T8
nice job!
Kialoa
Kialoa
Massachusetts
911, Cayenne
Since the last Fig was readable - thought I'd share the estimated impact of the interior color selection. The Black Mtn data is not shown again (was on last Fig) - and is only indicated by black line here. Forest Edge data is in Green with Red Text - clearly right-shifted (delayed). On closer inspection Ocean Coast data (light blue, Black Text) is more complex. Almost seems like a bimodal distribution - SOME of the orders are minimally (0-1 week) delayed wrt Black Mtn. Anther set of orders almost overlap with Forest edge delays. As always, there are some outliers...
Rivian R1T R1S ? Rivian Delivery Window Survey Results [Data & Trend Analysis Added] Survey_2
Rivian R1T R1S ? Rivian Delivery Window Survey Results [Data & Trend Analysis Added] survey_2-png
Rhidan
How did you pick the estimated delivery date for each R1T from among the two month window given?
Kialoa
Kialoa
Massachusetts
911, Cayenne
One of the many assumptions I had to build in. I scaled this based on the order date, assuming the data we have are a normal distribution - which it is not. So those that ordered earliest I put near the beginning of the relevant delivery window, and those that ordered latest near the end of that delivery window. Certainly imperfect - but since this seems to be the driving prioritization variable, maybe not too far off. Of course this is most error prone for the delivery windows with fewest respondents (least normal population).
