Should I change my configuration to get the power tonneau?
NathanB
Tesla model 3
I ordered last week R1T and I am expecting to take delivery next week.
My configuration is:
Quad motor, granite, ocean coast with ash wood internal and 22" bright
I got $3000 insentive to upgrade to the quad.
When I saw that rivian start offering the power tonneau for $500 I contacted my guide who told me if I want the power tonneau, I'll need to find another vehicle in store if I want one.
I found two similar configurations
Get a similar config with El cap granite, but with PDM and pay extra for reinforced underbody shield and power tonneau for $500
Get a similar config but with Limestone and not El Cap with the power tonneau for $500
Or I can take delivery of what I ordered and add the power tonneau retrofit sometime in late 2024 (with an uknown cost and install date)
What would you do in my case?
Soupdc
Duncan
Dallas, TX
2016 GMC Yukon
I dunno. I picked my R1T up on June 30, 2022. Power Tonneau broke July 3, 2022. It was not working when I traded my R1T in for the R1S in December 2023. So I never really had a working one to be able to tell you if you should do it.
brancky3
Brandon
Greenville, SC
22 CY R1T, 21 MachE GT
Having a manual tonneau quad myself, I would definitely recommend getting the auto cover instead. The manual isnā€™t bad at all (LOVE how it looks) but it takes 5 minutes to get the bag out, uninstall it, zip the bag up, take everything out of the gear tunnel, then put the bag in.
I would do this every day instead of downgrading to a dual motor though, to be fair.
Budman
Rick
Minnesota
Honda CRV
I have a quad R1T with auto tonneau. Approaching two years old. My cover has always worked well but I use it infrequently. It is very handy. If you plan to use the cover a lot I would go auto. Manual if expecting seldom use.
Ecupip
NC
Rivian, Audi, and 2 Jeeps
For $500 that is a no-brainer for me. Go for the power cover. They replaced mine recently (disabled since taking delivery), zero issues so far.
golden_frog
Golden
Southern IL
700k
I have both quad motor and powered tonneau. If I had to choose one, I guess it would be the quad motor. But the powered tonneau provides a hell of a lot more value for $500 than quad motor does for $8000
MidnightRivian
gvtucker
North Carolina
To each their own. When I ordered initially, I got the manual cover instead of the powered, because that always seemed to be the sort of thing that would break. And for many, it sounds like the powered cover does break more often than not.
I don't mind spending the couple of minutes to take off the manual cover. Others do. Ob-la-di, ob-la-da, life goes on.
WallStand
USA, New-York
Congrats on the R1T! Power tonneau key for you? If so, finding a pre-built truck with it might be best. Open to waiting? Retrofit is an option later in 2024, but cost and timing are unknowns. Existing trucks offer the power tonneau with either El Cap features (and extra cost) or your preferred granite color. Go with what matters most to you!
srnyoung
Nate
Portland, Oregon
Teacher
I have the manual cover, use it ~weekly.
If I had the choice, I'd take a (high-functioning, not prone to breaking) power cover ONLY because it stores itself. I hate having to find somewhere to put the cover when I have a big load. The gear tunnel works but I keep a fair bit of stuff in there regularly so it's a challenge.
GeekDoc
Akron, OH and Atlanta, GA
Jeep Wrangler Sahara
Physician
I have PDM max and the manual tonneau. I mostly keep the cover on and donā€™t mind the 4 minutes to remove it and put in the gear tunnel.
Really up to you on whatā€™s more important to you and what you are willing to sacrifice. There is one share of ā€œnewā€ and improved powered cover failure. We donā€™t know cause unfortunately. But with added complexity, it is and will always be additional failure points at some point. Trade convenience for that or vice versa? Iā€™m on the fence, but leaning slightly towards keeping the manual cover. If Rivianā€™s Service was more robust, with wait times of a couple weeks, Iā€™d be less conservative. Where you keep your truck most of the time likely matters too. If outside and frequently exposed to debris, risk of failure is probably higher. It doesnā€™t look like they added a second motor, but adjusted tolerances and spring tension.
