Simple Internal Apple MagSafe mod - STL attached
kozak79
New Jersey
www.youtube.com
Visual Effects
I wanted to try and make a simpler internal MagSafe mod, replacing the Rivian charging pad. Worked pretty well. You can still use the original rubber pad and your MagSafe equipped iPhone won't slide anymore. I'm still working on cable management and will update tomorrow.
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230129_020103346_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230129_020214089_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230129_020236617_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached magSafeInner
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached Screenshot 2023-01-28 151147
flightlevel
Dan
rivian
Awesome, thank you!
This works through the oem rubber? How are you connecting the power?
kozak79
kozak79
New Jersey
www.youtube.com
Visual Effects
Awesome, thank you!
I have a new version that I will upload soon. It does work mostly through the rubber, the magnet works, but the charging usually works. I'm toying with using a router to shave down some of the rubber for a better connection. I'm using the USB-C ports in the storage area to charge. I'll share more pictures tomorrow.
protamine
Cincinnati
LG R1S, 992 GTS
CT Surgery
If you ever make a run of these (or conversely someone with printer access) put me down for one!
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Jeep & R1T & Silverado EV
This is where I started last year at the early stages of when I made my original replacement it. I found that despite the obviousness of the solution, it never worked well enough. The OEM pads weren't strong enough to either hold a phone in place during driving, or push a signal through the rubber pad on a consistent basis.
Some of the time it did one or the other, but it all basically fell apart when there was any cornering or when you start to have any variation of cases involved. It's why I had to go to a third-party pad. I ended up evaluating almost a dozen of them before I found one that worked consistently.
I think shaving of the pad (or replacing it) will need to happen for this concept to work.
Sorry to be the bearer of bad news.
kozak79
kozak79
New Jersey
www.youtube.com
Visual Effects
I wouldn’t do it if it wasn’t fun :) I love tinkering and 3D modeling/printing. Love your products and that your share your STL’s ;)
I might try printing a new rubber mat in TPU if I can get a decent enough 3D scan out of it.
kozak79
kozak79
New Jersey
www.youtube.com
Visual Effects
OK, here's my final design. I had to break it into 2 parts because you need to print the bottom of the charging plate flat on the print bed. When it cools it will slightly bow up and push the pucks up instead of down. The feet can be either screwed in as I did or super glued, which I tried on another print and it worked just as well. The MagSafe pucks are slightly proud and I printed a router guide to take off about a 1/16 of an inch under the rubber mat. The guide is held down by double-stick tape. I used the same double-stick tape to attach the pad to the housing. You can see in the pictures that the magnets are holding well at more than 45 degrees, it's easy to find home on the charging pad.
I also cut the tabs off on the rubber mat for the cables.
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 3dModel
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230131_005357225_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230131_011459938_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230131_011506349_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230131_011517468_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230131_012701820_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230131_013251983_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230131_013335718_iOS
Rivian R1T R1S Simple Internal Apple MagSafe mod - STL attached 20230131_013451399_iOS
Printed in PETG in .25 draft settings with 15% infill with a brim. Print time was 4.5 hours.
Prime
SoCali
Tesla MY(P), Rivian R1T
This is awesome! So you pulled out the old charging unit all together?
