spatlennon
- Thread starter
- #1
Left turn signal on trailer only works when head lights are off. I also get a warning in the Rivian that there is a connection issue. I used a tester at 7 pin connection to confirm the Rivian appears to be wired correctly. I assumed I may have a recent grounding issue on the trailer (all worked ok a few weeks ago with old car.) but tested trailer with multimeter and had continuity throughout. The trailer has a 4 pin flat connector and Iām using an adapter - I tried 3 different ones, none worked. Has anyone else had an issue using a 4-7 adapter? My next trouble shooting step is to see if the trailer works properly on another truck/car. Trailer is 3 years old with led lights. Rivian is ā24 R1S. Thanks!!
