What max range calculations is everyone getting?
rivian1800
Nlg
What kind of drives do you typically do? Mode most driving is done in, tires? If you're averaging 57mph over 7400 miles I'm guessing most driving is longer highway drives, and the battery comes to temperature.
I have seen 2.2-2.4 fairly recently when I've driven 60-65mph and the drive was long enough to let the battery warm up. In all-purpose, normal height, all-terrains. Most of my driving though is relatively short, about 16 miles and 25 minutes. By the end of the drive the numbers always come up, but getting the battery up to temp absolutely kills the efficiency initially.
I’ve been driving for 10 days in cross country trip and it was done only in conserve mode (22’ sports) and those are the numbers. Regarding the tires, I will be posting the numbers (thread depth) after 23.000+ miles. I put the second set of tires on 3rd of December for the winter season but I have some life remaining on the older tires to be used for the spring-fall season.
jjswan33
Joshua
Sandy, OR
@godfodder0901 is the only person i can recall who's vehicle's estimated range has changed since delivery.
Mine has been slowly going up since the last update. Now at 278 for All Purpose from the usual 270 to start. Conserve and Sport haven’t changed but I have only been driving in AP and Snow modes since it started snowing in the mountains.
Rivian R1T R1S What max range calculations is everyone getting? 21676C51-1436-410C-B1A9-3AEA33C95285
Andystroh
Andrew
Almost identical experience here. We are at 280. Same sport and conserve values.
SeaGeo
Brice
Xc60 T8
Same.
Kitsap, WA
Echoing others, I'm seeing more since the last update both in the truck and in the app. I'm currently seeing 290 estimate with AP selected via app math (203/.7). Unless it's showing the max milage possible in the app instead? It used to read ~190 at 70%.
Rivian R1T R1S What max range calculations is everyone getting? Screenshot_20230107-221935~2
electricRaptor
Ian
Westminster, CO
Cloud Architect
Figured I’d chime into this thread now too. Just charged to 100% overnight and left it plugged in until I set off. Showed conserve 298. I got on the road and for the first 12 or so miles, it didn’t drop below 298. I found this thread while nervously googling “R1T estimated range stuck” ?
Rivian R1T R1S What max range calculations is everyone getting? 78AAFDDB-CD5D-4FC0-9F1C-F176AB276F66
Rivian R1T R1S What max range calculations is everyone getting? 09852729-A32A-4A5F-8DFD-E8899656E2F3
DJG
TX
Various
288mi is what is reported in AP on AT's, but implied is near 300. The 288 has been steadily increasing over the past couple weeks though.
Same as last poster, if I charge to 100% it will say something similar to this reported full range but then not decrease for the first 10-15 miles.
Rivian R1T R1S What max range calculations is everyone getting? 1673823370803
Mark_AZR1T
Gilbert, AZ
jackpucks.com
R1T Launch, R1S Canyon Red
311 miles at 97% on Conserve 20 ATs....this has made a significant shift upwards in the past 4 days.....
Rivian R1T R1S What max range calculations is everyone getting? 20230113_164805
electricRaptor
Ian
Westminster, CO
Cloud Architect
307 for conserve on 20” ATs now. Accurate or not, I like this
Rivian R1T R1S What max range calculations is everyone getting? 67B6C4B1-C6A3-4C70-BE83-11446E39E730
John G.
Vancouver, Washington USA
Now I'm showing 320 miles for AP, which is mostly what I drive for in city driving, on 22" Sport Wheels. I've only gone about 2,700 miles so far, and normally charge up to 70%.
Rivian R1T R1S What max range calculations is everyone getting? 20230115_153254
