connoisseurr
Connor
Northern VA
22 R1T, 23 MYP
I encrypt PDFs for Boomers
Over the past two weeks, I’ve read two unrelated posts on Reddit about owners being told by service center technicians that conserve mode should only be selected while the vehicle is stopped. This is being shared by Rivian service AFTER owners are having rear drive units replaced due to drivetrain malfunctions.
I’d like to know if any other owners have heard this directly from Rivian? There’s nothing in the owners manual, nor within any forms publication from Rivian.
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
I almost always select conserve on the fly, while getting on a freeway usually. If true, this is concerning.
EVnewb
Dustin
Clarksville, MD
Sienna, Tesla MYP, R1T
Thanks for the heads up on this! Going to do it when stopped from now on just to be safe.
Andystroh
Andrew
I am sure there are best practices, but if this was the concerning at all I bet Rivian would have required that through the software?
connoisseurr
connoisseurr
Connor
Northern VA
22 R1T, 23 MYP
Agree. My standard practice is to throw it into conserve mode when I'm at at highway speeds and know I won't be in any stop and go for a while.
Not so much a heads up, but more of a poll to see if anyone else has heard this rumor.
Agree. Someone else on Reddit also mentioned this exact comment. If it were by design, there would be a software limitation to active Conserve mode while in motion.
IRun
Julian
Perrysburg, OH
R1T Adventure, Model 3
Analyst
I was having issues on a 2 hour trip switching from conserve to sport on the fly, could clearly feel the 4 wheel drive kick in with a clunk feeling.
jpa5635
Network Nerd
FWIW I had a "service suspension soon" with hold failures and loss of pedal soon after switching to conserve on the fly last weekend. After a reset and staying in conserve the warnings were still present. After reset and changing to all purpose while parked, the errors cleared and I haven't seen them since. I've been running in all purpose since and have no plans to return to conserve.
CommodoreAmiga
INACTIVE
INACTIVE
If that were true, then they should restrict the mode change in software.
atebit
R1T, Porsche Boxster
Not to say “anecdotal” (on the part of the technician),but…anecdotal.
The only times I changed were on the fly. I don't need conserve unless I'm on the freeway and I was under the understanding that conserve was only intended for things like freeway driving not driving around town. We are getting some real mixed messages here.
Jack Smoke
Milwaukee
Corvette Z06, Cherokee, Nissan Titan, BMW 1200GSA
Being a bit n the older side, 49, and growing up with locking hubs. It’s an old habit to ”change modes” 2x4 to 4x4 while in neutral (best practice) or Park usual practice. Neutral only to go into 4x4 low range, as per every OEM. I know “shift on the fly” has been around for decades. But something about old dogs and new tricks. You guys do what you want, but I’ll either start in the mode I plan on doing most of my driving in or wait for a stoplight.
kurtlikevonnegut
SC/TX
2023 R1S DM, Honda Odyssey
I'm the same way and when I have changed to Conserve while driving I wince. Whenever possible if I do go to Conserve I try to do it on the onramp or at a light before getting on the interstate. The more I drive and get comfortable with the range the less I see a need for Conserve. I think I'd only even use it if I absolutely need it to get where I'm going since it really only makes a 20-30 mile difference at highway speeds. I see similar efficiency gains by going 65-70 instead of 75 as going to Conserve from AP, so I'd rather just drive slower honestly.
Sgt Beavis
Rick
Overpaid Computer Nerd
I don’t usually switch drive modes while in motion but you’d think they would put this in the code so users can’t change drive modes unless they are stopped.
Jack Smoke
Milwaukee
I’m a fan going slow and appreciating the scenery. Ive only used dynamic mode on my motorcycle twice, once to make sure it worked on a test drive, the other on an empty on-ramp. I imagine that I’ll use sport in the R1T a fair bit at first, then after I get bored of scaring myself, and showing off for friends and family. I’ll do most of my driving in conserve. Unless I know there’s a free charge at the end of the line :)
