krtrice
Keith
Stopped by the proposed site to see if construction had started. Surprisingly, all stalls and electrical supply equipment appear installed but there was no power flowing yet.
Great location right off of I-94 in between two Tesla supercharger sites that I previously frequented on my weekend trips to northern Michigan. Happy to see more chargers added in the Midwest!
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! IMG_1287
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! IMG_1288
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! IMG_1290
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! IMG_1291
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! IMG_1293
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! IMG_1296
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! IMG_1297
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! IMG_1298
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! supply_1
Rivian R1T R1S Benton Harbor, Michigan RAN Chargers are installed! supply_2
Autolycus
ATL
ICE only :(
Interesting that those pedestals in Benton Harbor are oriented differently than most of the other stations. I'm guessing it was a clearance issue with the fence/property line.
Also, I agree with others who have commented on the "normal" orientation: It seems like the pedestal should be on the left side of the space with the screen facing to the right so you stand in front of your own car while using the screen.
Puttyandnapalm
West Virginia
R1T, 2008 Ram 1500, 2013 Triumph Trophy
Casino
I went to high school in this area, very surprising to see them installed there. Exciting!
2025R1S
Jacksonville
Ford Fiesta
This is interesting. I’m not sure what it says about Rivian.
The area has (2) Tesla supercharger locations (effectively an open network for all NACS vehicles, and open to CCS - pending retrofit). There is an EA location in-progress, in addition to a FlyingJ location in-progress.
I love seeing more CCS chargers, but this doesn’t move the needle for me. I would rather Rivian put the chargers in the Upper Peninsula, so that I could go somewhere new - more easily. For a closed network CCS charger to be put in Benton Harbor - it seems a bit redundant. Even if RAN was open, the charger could be used in a number of other locations.
To me, it seems like bad planning on Rivian. I hope Tesla doesn’t spend a bunch of taxpayer dollars installing more chargers where there are already a ton of chargers. For me, it’s all about being able to go to more places easily, so if there are existing DCFC - it seems pointless to add even more. Rivian should be using this RAN cash more wisely.
The only defense I have for Rivian here is the Superchargers around here are really busy, CCS chargers are a crapshoot with reliability - so if the EA or FlyingJ CCS chargers are down in Benton Harbor and the Superchargers have a line; there is now a backup just for Rivian drivers.
SDH
NC
Jeep
As mentioned, the first thing I noticed compared to other RAN's in the orientation of the charging units. RAN's I have visited have them turned 90 degrees and it made it a bit awkward to pull the cable up to the plug socket. Perhaps this works better??
timf
Tim
Novi, MI
2B and 2C look like they should be facing the other way.
Count Orlok
Wisconsin & New Mexico
any plans to install RAN at places people use?
Autolycus
ATL
ICE only :(
I was trying to figure out what to make of those. It seems to me like they should be facing the opposite direction from each other, maybe? It makes sense to have a pull-through on that lane, but having them both in the same lane seems counterproductive.
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
For those who have used RAN, is it actually plug-and-charge or do you have to interact with the screen?
timf
Tim
Novi, MI
The intent appears to be either one truck with trailer can pull through and charge on 2C, or if 2C is empty or does not have a trailer, 2B becomes available. They are currently facing a driveway, not parking spots.
Engineering, Dog Petting
Ran into the tech at Grayling and he said he turned up Benton Harbor yesterday. Next station in Michigan is probably going to be TC, but both TC and Saginaw are delayed because of parts shortages.
Plug&Charge. Don't have to do anything in the truck or the station. Seemed to activate faster than a normal free DC station too. I heard contactors somewhere about 2 seconds after the cable clicked into place. Very little wondering if it was going to work.
Marchin_MTB
Marcin
Thanks! I hope when they start charging for RAN soon, that it will continue to be that seamless.
