goldburger
No c+ - patiently waiting. I know C+ subcribers pay a premium for getting it early so I must learn to work on my patience and wait :) - I absolutely see value in C+ and plan on subscribing in the new year after all my Christmas expenses have cleared :)
I have connect plus and I’m still waiting too waited a while last time as well tbh. ¯\_(ツ)_/¯
The data service is the main value of it
Kitsap, WA
I don't see a thread with OP nicely listing all of the changes, and there's like 4 threads going on it, so I'll just drop this interesting find here. 2022 quad R1T.
-Gear Guard will use HV more and specifically mentions 12V health
-Drive Cam name change
Rivian R1T R1S 2024.47.0 Update Spotted! 1000001651
Installed the update yesterday and now my phone key stopped working. I also can’t lock the vehicle with my phone. Tried forgetting it from my Bluetooth devices and redoing the setup for the phone key, but it keeps connecting to the old key in my Bluetooth devices and setup doesn’t complete. Reached out to support and they’re saying I will have to bring it in for service. I also tried hard resetting the infotainment and the vehicle itself, none of it worked.
Have you tried deleting and reinstalling the phone app?
Cycliste
Solano County, California
Amateur aero weenie
It is early days, but my vampire drain is significantly lower in the two days on 2024.47.1
Rivian R1T R1S 2024.47.0 Update Spotted! IMG_1968
rzaruction
Rizwan
Princeton, NJ
R1S Gen 2
Supply Chain
I just tried that it doesn’t help. The problem is that the old key keeps connecting through Bluetooth when I’m trying to re-pair the phone even though I forgot the connection in my iPhone. I have an appointment with the service center to take a look at it.
runwithscissors
XC90, MDX, R1S
Dear Rivian, why after every single update do the cameras revert back to the default settings? Why can't they just keep the settings I had applied prior. So annoying...
raisethe4
n/a
Tech
Disappointed that this update did not fix the drive cam issue which has been going on for 3 months. Perfectly fine USB stick not recognized. Are others seeing the same issue when using a USB stick or are you having success using an external HDD, and so which one?
Rivian Roamer
rivianroamer.com
2024 R1S Quad Large, 2025 R1T Tri Max
Adventurer
Using USB sticks is generally not recommended. Constant writes to them really burns them out very quickly. If you want to rely on this when you need it most get an SSD. I've gone through so many USB sticks between my Teslas.
raisethe4
n/a
Tech
Is there a recommended SSD that is know to work with the Rivian through all these updates? Thank you
Rivian Roamer
rivianroamer.com
Adventurer
I don't think Rivian recommends one but I've had luck with this one.
https://amzn.to/3BPPUxy
Been using it for a few years now without issue.
I put this in my R1S in May 2023, have never had an issue with it, just seems to work. Here is a picture in, I used the cable and a Velcro strip to keep it tight to the front of the cubby.
Samsung
Cable - Looks like the cable is not available but this should work.
Rivian R1T R1S 2024.47.0 Update Spotted! IMG_0388
