RIV206
Bainbridge Island, WA
‘23 R1S, '25 R1T, '25 R1S
Anyone else notice weird HVAC fan speed issues after the update? I always use manual mode for my fan speed and I noticed today it was adjusting the speed by itself and not reacting right away if I tried to lower it.
It's been two days. Don't be a jerk. As usual, the rollout is spread out over time, with Connect+ subscribers getting it first, within the first week (that's your priority right there) then us non-Connect+ folks and other stragglers getting it starting the following week. Modulo a few problem cases.
And I think the order, among subscribers, is random. Most OTAs I get a week or more after first reports. This time I got it the day after.
I did not. Only 2 things I noticed was the satellite view was turned off on the map and I had to log into Tune-in. Not a surprise as I assume it is related to the additional user settings it is saving in the profile
Rivian Roamer
rivianroamer.com
2024 R1S Quad Large, 2025 R1T Tri Max
Adventurer
bluedragonr1s
Brentwood, TN
2025 R1S Dual Max
I installed 2025.14 last night, this morning the no audio was working on Spotify or Navigation. I had to do a soft reboot and the audio is now working again.
technerd
SE PA
2022 Bronco, 2022 R1T
Well it fixed my error swapping wheels & tires that the mobile tech couldn't figure out in 2 hours yesterday, that's always a plus.
RivianRiverRat
Greg
Chattanooga TN
2022 Rivian R1T
Civil Engineer
RivuanRoamer notified me yesterday that the update was queued up for my T
Made it home and updated on WiFi
Rear camera is now working but passenger outside mirror light won’t go off
beatle
Springfield, VA
Mine installed this morning. Confirmed the map view you select remains the same unless you change it again - great! Alexa voice volume also seemed to be fixed.
Replying to myself here. Maybe the map view isn't fixed after all. I drove to work this morning and the map view went back to zoomed in vs. the entire route.
As for general lingering issues that crop up after a software update, I have no idea why the truck doesn't do a "soft reset" at the end of the update process. I assume it is already rebooting, but weirdness is not uncommon. For example, the power meters on the tires in the suspension menu disappeared again. I'm sure a reboot will get them back, but it's just strange.
zefram47
Rivian R1T, Alfa Romeo 4C
Just had a short drive after updating. Anyone else with the G1 Meridian system feel like they lost a lot of low-end bass with this update? I haven't yet checked to see if something weird is going on with the EQ.
I don't think it's related to this update, but at least since the Dolby Atmos stuff released I haven't been able to use the Rock preset with Spotify because it's actually *too* bass-heavy and muddy. I've resorted to using the Jazz preset with Spotify and it seems okay. I also noticed that I can't use the same preset between Apple Music and Spotify because they just sound totally different with Atmos stuff that Apple Music has and Spotify doesn't.
runwithscissors
XC90, MDX, R1S
I still don't get why my camera views revert back to default on every single software update? How hard is it to retain the settings just like every other setting?
rvnappolis
Burr
Pilot; Outback
Government
I hope this will fix some bugs/ glitches in 2025.10.01. I’m having so many since then.
I've been holding out installing 2025.10 since improvemnts didn't seem all that earth shattering. Risk of bugs / lag didn't look worth it.
Should I go ahead and install now with the expectation that .14 will most likely correct any problems?
Only issue I had with 2025.10 was the Alexa voice was hosed. That was fixed in 2025.14, I’ve had mine a couple of days, seems pretty solid on my 22 R1S.
elektrode
Bran
NC
Honda Ridgeline to R1T
Same here on Apple Music with Atmos. Atmos is louder and WAY more bass heavy. Yes, I’ve turned off the “sound check” or whatever setting (that keeps getting switched back after updates). Some songs are unlistenable in Rock settings. Alice In Chains Dirt has a kick drum that swallows the world.
DayTripping
Timothy
DFW
2025.10 was one of the best releases in a while. You missed out on a lot, at least where the suspension is concerned. I've had no issues with it at all.
